주요 콘텐츠로 건너뛰기
Xelio P900A-BK Battery Replacement
필요한 것
  1. Xelio P900A-BK Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Using a #00 Phillips head screwdriver, remove the two 5.4mm bottom screws.
  2. Xelio P900A-BK Battery Replacement: 2 단계, 이미지 1/2 Xelio P900A-BK Battery Replacement: 2 단계, 이미지 2/2
    • Insert a plastic opening tool between the screen and the rear case and gently work your way around the tablet.
  3. Xelio P900A-BK Battery Replacement: 3 단계, 이미지 1/1
    • Using the plastic opening tool or your fingers, gently pry the pieces of the tablet apart. You will hear the plastic latches pop free.
  4. Xelio P900A-BK Battery Replacement: 4 단계, 이미지 1/3 Xelio P900A-BK Battery Replacement: 4 단계, 이미지 2/3 Xelio P900A-BK Battery Replacement: 4 단계, 이미지 3/3
  5. Xelio P900A-BK Battery Replacement: 5 단계, 이미지 1/2 Xelio P900A-BK Battery Replacement: 5 단계, 이미지 2/2
    • Carefully insert the flat end of a nylon spudger under the battery, and pry the battery up and away from the tablet casing.
    • A small amount of heat may be required to safely remove the battery from the adhesive underneath. Use an iOpener or heat gun to soften the adhesive.
    • Do not bend or puncture the battery.
    • Place the new battery in the same place as the old one, making sure it is oriented the same way as the old one was.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Marcus Nelson
회원 가입일: 03/26/15
307 평판
안내서 3개 작성하였습니다
UMass Dartmouth, Team 7-6, Cichon Spring 2015 UMass Dartmouth, Team 7-6, Cichon Spring 2015 회원
UMASSD-CICHON-S15S7G6
3 회원들
안내서 8개 작성하였습니다
댓글 한 개
I am attempting to fix one of these for a friend, but I can't seem to get it open! Does it require a significant amount of force? I am afraid I will break it...
skatermonkey06 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 2
전체 시간: 335
