주요 콘텐츠로 건너뛰기
Xiaomi Air 12 Motherboard Replacement
필요한 것
  1. Xiaomi Air 12 Motherboard Replacement, Rear Casing: 1 단계, 이미지 1개 중 1개
    • Orient the computer so the Xiaomi logo is at the bottom of the device.
    Hello,
    I have a problem on my Mi air 12 , specifically with the lcd cable port on the mother board. I want to replace it but i can’t seem to find where to buy the parts.
    Pleas help me
    Kind regards
    L.
    lanusjeleus - 답글
  2. Xiaomi Air 12 Motherboard Replacement: 2 단계, 이미지 3개 중 1개 Xiaomi Air 12 Motherboard Replacement: 2 단계, 이미지 3개 중 2개 Xiaomi Air 12 Motherboard Replacement: 2 단계, 이미지 3개 중 3개
    • Insert the plastic opening tool underneath the top-middle rubber covering and lift upwards to reveal the hidden screw.
  3. Xiaomi Air 12 Motherboard Replacement: 3 단계, 이미지 2개 중 1개 Xiaomi Air 12 Motherboard Replacement: 3 단계, 이미지 2개 중 2개
    • Remove the eight 3 mm screws using the Torx T5 driver by inserting the screwdriver into each screw and rotating counterclockwise.
  4. Xiaomi Air 12 Motherboard Replacement: 4 단계, 이미지 3개 중 1개 Xiaomi Air 12 Motherboard Replacement: 4 단계, 이미지 3개 중 2개 Xiaomi Air 12 Motherboard Replacement: 4 단계, 이미지 3개 중 3개
    • Insert the plastic opening tool into each side of the computer and push the tool downwards to pop open the back cover.
    • You will hear popping noises as you remove the cover.
  5. Xiaomi Air 12 Motherboard Replacement: 5 단계, 이미지 2개 중 1개 Xiaomi Air 12 Motherboard Replacement: 5 단계, 이미지 2개 중 2개
    • Remove the back of the laptop by gently lifting the casing upwards.
  6. Xiaomi Air 12 Motherboard Replacement, SSD: 6 단계, 이미지 2개 중 1개 Xiaomi Air 12 Motherboard Replacement, SSD: 6 단계, 이미지 2개 중 2개
    • Detach the white and black speaker wires by pulling them from the small black tabs along the perimeter of the metal bracket.
    Would be nice if I found somewhere a replacement for the Mainboard….no luck so far and Xiaomi does not sell.
    Mk k - 답글
  7. Xiaomi Air 12 Motherboard Replacement: 7 단계, 이미지 2개 중 1개 Xiaomi Air 12 Motherboard Replacement: 7 단계, 이미지 2개 중 2개
    • Remove the 1.5mm screw using the JIS #00 screwdriver.
  8. Xiaomi Air 12 Motherboard Replacement: 8 단계, 이미지 2개 중 1개 Xiaomi Air 12 Motherboard Replacement: 8 단계, 이미지 2개 중 2개
    • Lift the SSD up from the device and gently pull the SSD from the laptop.
  9. Xiaomi Air 12 Motherboard Replacement, Battery: 9 단계, 이미지 1개 중 1개
    • Detach the red wire from the tabs on the perimeter of the metal bracket.
  10. Xiaomi Air 12 Motherboard Replacement: 10 단계, 이미지 3개 중 1개 Xiaomi Air 12 Motherboard Replacement: 10 단계, 이미지 3개 중 2개 Xiaomi Air 12 Motherboard Replacement: 10 단계, 이미지 3개 중 3개
    • Use a PH1 screwdriver to remove the five 2mm black screws.
    • Remove two silver 1mm JIS #00 screws.
    • There will be clear plastic spacers that come off with the silver screws.
  11. Xiaomi Air 12 Motherboard Replacement: 11 단계, 이미지 3개 중 1개 Xiaomi Air 12 Motherboard Replacement: 11 단계, 이미지 3개 중 2개 Xiaomi Air 12 Motherboard Replacement: 11 단계, 이미지 3개 중 3개
    • Lift the battery up and pull out from the device.
    • The metal bracket will come out with the battery.
    Dont forget to disconnect the battery wire!!
    Ben Egalo - 답글
  12. Xiaomi Air 12 Motherboard Replacement, Motherboard: 12 단계, 이미지 2개 중 1개 Xiaomi Air 12 Motherboard Replacement, Motherboard: 12 단계, 이미지 2개 중 2개
    • Lift the silver connection cover next to the USB ports using the plastic opening tool and your hands.
    In newer version, you don't have to do this part. You can just pull out the webcam cable without removing the cover
    Wouter - 답글
  13. Xiaomi Air 12 Motherboard Replacement: 13 단계, 이미지 3개 중 1개 Xiaomi Air 12 Motherboard Replacement: 13 단계, 이미지 3개 중 2개 Xiaomi Air 12 Motherboard Replacement: 13 단계, 이미지 3개 중 3개
    • Remove the four ribbon cables by lifting the connector up with the plastic opening tool and pulling the ribbon cable out.
  14. Xiaomi Air 12 Motherboard Replacement: 14 단계, 이미지 3개 중 1개 Xiaomi Air 12 Motherboard Replacement: 14 단계, 이미지 3개 중 2개 Xiaomi Air 12 Motherboard Replacement: 14 단계, 이미지 3개 중 3개
    • Disconnect the gray and black wire connectors using the plastic opening tool to lift them up.
  15. Xiaomi Air 12 Motherboard Replacement: 15 단계, 이미지 2개 중 1개 Xiaomi Air 12 Motherboard Replacement: 15 단계, 이미지 2개 중 2개
    • Remove the webcam connector by gently pulling the cable out by hand.
  16. Xiaomi Air 12 Motherboard Replacement: 16 단계, 이미지 2개 중 1개 Xiaomi Air 12 Motherboard Replacement: 16 단계, 이미지 2개 중 2개
    • Lift the video cable on the connector using the plastic opening tool to disconnect it.
  17. Xiaomi Air 12 Motherboard Replacement: 17 단계, 이미지 2개 중 1개 Xiaomi Air 12 Motherboard Replacement: 17 단계, 이미지 2개 중 2개
    • Remove the seven black 2mm screws using a PH1 screwdriver.
  18. Xiaomi Air 12 Motherboard Replacement: 18 단계, 이미지 3개 중 1개 Xiaomi Air 12 Motherboard Replacement: 18 단계, 이미지 3개 중 2개 Xiaomi Air 12 Motherboard Replacement: 18 단계, 이미지 3개 중 3개
    • Gently lift the motherboard out by hand.
    Where can I buy the motherboard?
    muthu.babu - 답글
    подскажи, где купить материнку??
    Pal Zhenilov - 답글
    What is the motherboard name? Where can i buy it?
    Andrea Amicosante - 답글
    Any type number for the logic board / motherboard behind the cooling?
    David Beckershoff - 답글
결론
다른 5명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Hannah Kwan
회원 가입일: 04/18/18
869 평판
안내서 5개를 작성함
Cal Poly, Team S18-G4, Livingston Spring 2018 Cal Poly, Team S18-G4, Livingston Spring 2018 회원
CPSU-LIVINGSTON-S18S18G4
4 회원들
안내서 24개를 작성함
11가이드 댓글
Where do you order a replacement?
I couldn’t find any parts for my Xiaomi air 12.
Jon Jag - 답글
di you get it?
zelenmix -
Same here. Where to get motherboard to xiaomi mi 12?
imthespace - 답글
Did yoiu get it?
zelenmix -
... I would like to replace but I can't find a motherboard anywhere ... can anyone help me, where to buy the board for best price?
Aljoša Jelen - 답글
Have you got it?
zelenmix -
Hi where i can buy mothreboard to replacrñe….?
Best regards
Tipitao Tipitao - 답글
Hi, I am also searching for the motherboard, Did you find it?
Please guide me
maaz siddiqui - 답글
Hello,
Are these motherboards that bad? Got one notebook here that is dead. Battery replacement did not help.
Roland
Roland Wandera - 답글
Hello, could you get the guide to change the keyboard?
Gerardo Rangel M - 답글
I'd also like to replace the keyboard, have you found a good guide by chance (and a good replacement)?
Andrea Arieti -
댓글 쓰기
조회 통계:
지난 24시간: 6
지난 7일: 71
지난 30일: 482
전체 시간: 5,113
