소개
Use this guide to replace a broken rear glass panel on your Xiaomi Mi 11 Lite.
If you do not replace the adhesive seals when reassembling, your device will function normally, but will most likely lose its water protection.
You’ll need replacement adhesive to reattach components when reassembling the device.
필요한 것
Prepare an iOpener and apply it to the rear glass for at least two minutes to loosen the adhesive underneath.
Secure a suction handle to the right edge of the rear glass, as close to the edge as possible.
Lift the rear glass with the suction handle to create a small gap between the rear glass and the frame.
Insert an opening pick into the gap you created.
Slide the opening pick to the top right corner to slice the adhesive.
Leave the opening pick in place to prevent the adhesive from resealing.
Insert a second opening pick underneath the top right corner of your phone.
Slide the opening pick along the right edge to slice the adhesive.
Leave the opening pick in the bottom right corner to prevent the adhesive from resealing.
Compare your new replacement part to the original part. You may need to transfer remaining components or remove adhesive backings from the new part before you install it.
To reassemble your device, follow these instructions in reverse order. Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
다른 7명이 해당 안내서를 완성하였습니다.
