소개
Use this guide to replace the rear glass on your Xiaomi Poco F3.
You'll need replacement adhesive in order to complete this repair.
필요한 것
Prepare an iOpener and apply it to the rear glass for at least two minutes to loosen the adhesive underneath.
Secure a suction handle to the right edge of the rear glass, as close to the edge as possible.
Lift the rear glass with the suction handle to create a small gap between the rear glass and the frame.
Insert an opening pick into the gap you created.
Slide the opening pick to the top right corner to slice the adhesive.
Leave the opening pick in place to prevent the adhesive from resealing.
다른 4명이 해당 안내서를 완성하였습니다.
댓글 4개
Do I have to remove the whole back?
Can't I just remove the glass back?
Hi, yes, you have to remove the complete rear glass. Good luck with the repair!
