주요 콘텐츠로 건너뛰기
Xtreme Gaming XG-700 Internal Switch Replacement
필요한 것
  1. Xtreme Gaming XG-700 Internal Switch Replacement, Switch: 1 단계, 이미지 1/1
    • Flip the mouse over and peel off the two feet at the bottom of the mouse.
    • Using a Phillips #000 screwdriver, remove the two 5.6 mm screws.
  2. Xtreme Gaming XG-700 Internal Switch Replacement: 2 단계, 이미지 1/1
    • Carefully separate the base of the mouse from the top case as there are ribbon connectors holding the two pieces together.
    • Don't yank or pull the two pieces apart or you will rip the cables.
  3. Xtreme Gaming XG-700 Internal Switch Replacement: 3 단계, 이미지 1/3 Xtreme Gaming XG-700 Internal Switch Replacement: 3 단계, 이미지 2/3 Xtreme Gaming XG-700 Internal Switch Replacement: 3 단계, 이미지 3/3
    • Carefully remove the two cables from their connection point.
    • The top half of the case can be set aside.
  4. Xtreme Gaming XG-700 Internal Switch Replacement: 4 단계, 이미지 1/2 Xtreme Gaming XG-700 Internal Switch Replacement: 4 단계, 이미지 2/2
    • Using a small plastic spudger, release the four clips from each corner of the board.
    • Gently remove the board out of the case.
    • Don't yank or pull the board off the case. There is one cable connecting the board to the case.
  5. Xtreme Gaming XG-700 Internal Switch Replacement: 5 단계, 이미지 1/1
    • Carefully disconnect the ribbon cable from the board.
    • Set aside the case.
  6. Xtreme Gaming XG-700 Internal Switch Replacement: 6 단계, 이미지 1/2 Xtreme Gaming XG-700 Internal Switch Replacement: 6 단계, 이미지 2/2
    • Flip the motherboard over, and using a soldering iron, desolder the three switch prongs on each side of the switch.
    • Remove the broken switch.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Nam Nguyen
회원 가입일: 06/30/22
154 평판
안내서 1개 작성함
York University, Team M-18, Allen Summer 2022 York University, Team M-18, Allen Summer 2022 회원
YORK-ALLEN-SU22SMG18
1 회원
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 7
30일 전: 41
전체 시간: 924
