주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
YCCTEAM YCC-SW4001 ABXY Buttons Replacement
필요한 것
  1. YCCTEAM YCC-SW4001 ABXY Buttons Replacement, Front Case: 1 단계, 이미지 1개 중 1개
    • Use a Phillips screwdriver to remove the eight 9.15 mm screws that secure the rear case.
    댓글 쓰기
  2. YCCTEAM YCC-SW4001 ABXY Buttons Replacement: 2 단계, 이미지 3개 중 1개 YCCTEAM YCC-SW4001 ABXY Buttons Replacement: 2 단계, 이미지 3개 중 2개 YCCTEAM YCC-SW4001 ABXY Buttons Replacement: 2 단계, 이미지 3개 중 3개
    • Use an opening pick to pry the back cover off of the controller.
    댓글 쓰기
  3. YCCTEAM YCC-SW4001 ABXY Buttons Replacement: 3 단계, 이미지 1개 중 1개
    • Use a Phillips screwdriver to remove the three 9.15 mm screws from the back of the controller.
    댓글 쓰기
  4. YCCTEAM YCC-SW4001 ABXY Buttons Replacement, Remove two additional screws: 4 단계, 이미지 1개 중 1개
    • On some models there are two more Phillips head screws on the sides that need to be removed before the front and back panels can be separated.
    댓글 쓰기
  5. YCCTEAM YCC-SW4001 ABXY Buttons Replacement: 5 단계, 이미지 3개 중 1개 YCCTEAM YCC-SW4001 ABXY Buttons Replacement: 5 단계, 이미지 3개 중 2개 YCCTEAM YCC-SW4001 ABXY Buttons Replacement: 5 단계, 이미지 3개 중 3개
    • Slightly lift the front case.
    • Do not remove the front cover completely; it is still attached to the motherboard by a white ribbon cable.
    댓글 쓰기
  6. YCCTEAM YCC-SW4001 ABXY Buttons Replacement: 6 단계, 이미지 3개 중 1개 YCCTEAM YCC-SW4001 ABXY Buttons Replacement: 6 단계, 이미지 3개 중 2개 YCCTEAM YCC-SW4001 ABXY Buttons Replacement: 6 단계, 이미지 3개 중 3개
    • Use the tip of the opening pick to flip up the black locking flap of the ZIF connector.
    • The black flap holds the white ribbon cable in place.
    댓글 쓰기
  7. YCCTEAM YCC-SW4001 ABXY Buttons Replacement: 7 단계, 이미지 2개 중 1개 YCCTEAM YCC-SW4001 ABXY Buttons Replacement: 7 단계, 이미지 2개 중 2개
    • Use tweezers to disconnect the white ribbon cable from the ZIF connector.
    댓글 쓰기
  8. YCCTEAM YCC-SW4001 ABXY Buttons Replacement: 8 단계, 이미지 1개 중 1개
    • Remove the front case.
    댓글 쓰기
  9. YCCTEAM YCC-SW4001 ABXY Buttons Replacement, ABXY Buttons: 9 단계, 이미지 3개 중 1개 YCCTEAM YCC-SW4001 ABXY Buttons Replacement, ABXY Buttons: 9 단계, 이미지 3개 중 2개 YCCTEAM YCC-SW4001 ABXY Buttons Replacement, ABXY Buttons: 9 단계, 이미지 3개 중 3개
    • Isolate the front cover.
    • Flip over the front cover and remove the four 5.77 mm screws from the back of the front cover using the Phillips #1 Screwdriver.
    댓글 쓰기
  10. YCCTEAM YCC-SW4001 ABXY Buttons Replacement: 10 단계, 이미지 3개 중 1개 YCCTEAM YCC-SW4001 ABXY Buttons Replacement: 10 단계, 이미지 3개 중 2개 YCCTEAM YCC-SW4001 ABXY Buttons Replacement: 10 단계, 이미지 3개 중 3개
    • Lift the circuit board from the front cover to expose the back of the buttons.
    댓글 쓰기
  11. YCCTEAM YCC-SW4001 ABXY Buttons Replacement: 11 단계, 이미지 3개 중 1개 YCCTEAM YCC-SW4001 ABXY Buttons Replacement: 11 단계, 이미지 3개 중 2개 YCCTEAM YCC-SW4001 ABXY Buttons Replacement: 11 단계, 이미지 3개 중 3개
    • Remove the rubber caps and the button caps by either dumping them out or taking them out by hand.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Sam Borwick
회원 가입일: 02/15/24
333 평판
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 34
전체 시간: 503
