주요 콘텐츠로 건너뛰기
YCCTEAM YCC-SW4001 Battery Replacement
필요한 것
  1. YCCTEAM YCC-SW4001 Battery Replacement, Front Case: 1 단계, 이미지 1개 중 1개
    • Use a Phillips screwdriver to remove the eight 9.15 mm screws that secure the rear case.
  2. YCCTEAM YCC-SW4001 Battery Replacement: 2 단계, 이미지 3개 중 1개 YCCTEAM YCC-SW4001 Battery Replacement: 2 단계, 이미지 3개 중 2개 YCCTEAM YCC-SW4001 Battery Replacement: 2 단계, 이미지 3개 중 3개
    • Use an opening pick to pry the back cover off of the controller.
  3. YCCTEAM YCC-SW4001 Battery Replacement: 3 단계, 이미지 1개 중 1개
    • Use a Phillips screwdriver to remove the three 9.15 mm screws from the back of the controller.
  4. YCCTEAM YCC-SW4001 Battery Replacement: 4 단계, 이미지 3개 중 1개 YCCTEAM YCC-SW4001 Battery Replacement: 4 단계, 이미지 3개 중 2개 YCCTEAM YCC-SW4001 Battery Replacement: 4 단계, 이미지 3개 중 3개
    • Slightly lift the front case.
    • Do not remove the front cover completely; it is still attached to the motherboard by a white ribbon cable.
  5. YCCTEAM YCC-SW4001 Battery Replacement: 5 단계, 이미지 3개 중 1개 YCCTEAM YCC-SW4001 Battery Replacement: 5 단계, 이미지 3개 중 2개 YCCTEAM YCC-SW4001 Battery Replacement: 5 단계, 이미지 3개 중 3개
    • Use the tip of the opening pick to flip up the black locking flap of the ZIF connector.
    • The black flap holds the white ribbon cable in place.
  6. YCCTEAM YCC-SW4001 Battery Replacement: 6 단계, 이미지 2개 중 1개 YCCTEAM YCC-SW4001 Battery Replacement: 6 단계, 이미지 2개 중 2개
    • Use tweezers to disconnect the white ribbon cable from the ZIF connector.
  7. YCCTEAM YCC-SW4001 Battery Replacement: 7 단계, 이미지 1개 중 1개
    • Remove the front case.
  8. YCCTEAM YCC-SW4001 Battery Replacement, Battery: 8 단계, 이미지 3개 중 1개 YCCTEAM YCC-SW4001 Battery Replacement, Battery: 8 단계, 이미지 3개 중 2개 YCCTEAM YCC-SW4001 Battery Replacement, Battery: 8 단계, 이미지 3개 중 3개
    • Remove the two joystick covers by gripping them and pulling them straight upward with moderate force.
  9. YCCTEAM YCC-SW4001 Battery Replacement: 9 단계, 이미지 3개 중 1개 YCCTEAM YCC-SW4001 Battery Replacement: 9 단계, 이미지 3개 중 2개 YCCTEAM YCC-SW4001 Battery Replacement: 9 단계, 이미지 3개 중 3개
    • Use tweezers to grip the white plastic battery connector. Lift it directly it up and out of its socket.
    • Do not pull on the wires.
    • When replacing the battery, press the plug down into the socket until it snaps into place.
  10. YCCTEAM YCC-SW4001 Battery Replacement: 10 단계, 이미지 3개 중 1개 YCCTEAM YCC-SW4001 Battery Replacement: 10 단계, 이미지 3개 중 2개 YCCTEAM YCC-SW4001 Battery Replacement: 10 단계, 이미지 3개 중 3개
    • Use a Phillips screwdriver to remove the three 7.5 mm screws that secure the motherboard.
    • Remove the player LEDs from the motherboard.
  11. YCCTEAM YCC-SW4001 Battery Replacement: 11 단계, 이미지 3개 중 1개 YCCTEAM YCC-SW4001 Battery Replacement: 11 단계, 이미지 3개 중 2개 YCCTEAM YCC-SW4001 Battery Replacement: 11 단계, 이미지 3개 중 3개
    • Gently lift the motherboard up and out of the controller and set it directly between the grips.
    • Take care not to damage the rumble motor connections.
  12. YCCTEAM YCC-SW4001 Battery Replacement: 12 단계, 이미지 1개 중 1개
    • Use a spudger to gently lever the battery out of the controller.
    • The battery is attached with adhesive, so gently sever the adhesive around the entirety of the battery as you pry.
    • Take care not to puncture or bend the battery.
    • If your new battery does not come with adhesive, apply new adhesive to secure the battery.
결론
작성자
3다른 기여자 명과 함께
David Adaway
회원 가입일: 02/16/24
537 평판
안내서 4개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 15
전체 시간: 296
