주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
YCCTEAM YCC-SW4001 Shoulder Buttons Replacement
필요한 것
  1. YCCTEAM YCC-SW4001 Shoulder Buttons Replacement, Front Case: 1 단계, 이미지 1개 중 1개
    • Use a Phillips screwdriver to remove the eight 9.15 mm screws that secure the rear case.
    댓글 쓰기
  2. YCCTEAM YCC-SW4001 Shoulder Buttons Replacement: 2 단계, 이미지 3개 중 1개 YCCTEAM YCC-SW4001 Shoulder Buttons Replacement: 2 단계, 이미지 3개 중 2개 YCCTEAM YCC-SW4001 Shoulder Buttons Replacement: 2 단계, 이미지 3개 중 3개
    • Use an opening pick to pry the back cover off of the controller.
    댓글 쓰기
  3. YCCTEAM YCC-SW4001 Shoulder Buttons Replacement: 3 단계, 이미지 1개 중 1개
    • Use a Phillips screwdriver to remove the three 9.15 mm screws from the back of the controller.
    댓글 쓰기
  4. YCCTEAM YCC-SW4001 Shoulder Buttons Replacement, Remove two additional screws: 4 단계, 이미지 1개 중 1개
    • On some models there are two more Phillips head screws on the sides that need to be removed before the front and back panels can be separated.
    댓글 쓰기
  5. YCCTEAM YCC-SW4001 Shoulder Buttons Replacement: 5 단계, 이미지 3개 중 1개 YCCTEAM YCC-SW4001 Shoulder Buttons Replacement: 5 단계, 이미지 3개 중 2개 YCCTEAM YCC-SW4001 Shoulder Buttons Replacement: 5 단계, 이미지 3개 중 3개
    • Slightly lift the front case.
    • Do not remove the front cover completely; it is still attached to the motherboard by a white ribbon cable.
    댓글 쓰기
  6. YCCTEAM YCC-SW4001 Shoulder Buttons Replacement: 6 단계, 이미지 3개 중 1개 YCCTEAM YCC-SW4001 Shoulder Buttons Replacement: 6 단계, 이미지 3개 중 2개 YCCTEAM YCC-SW4001 Shoulder Buttons Replacement: 6 단계, 이미지 3개 중 3개
    • Use the tip of the opening pick to flip up the black locking flap of the ZIF connector.
    • The black flap holds the white ribbon cable in place.
    댓글 쓰기
  7. YCCTEAM YCC-SW4001 Shoulder Buttons Replacement: 7 단계, 이미지 2개 중 1개 YCCTEAM YCC-SW4001 Shoulder Buttons Replacement: 7 단계, 이미지 2개 중 2개
    • Use tweezers to disconnect the white ribbon cable from the ZIF connector.
    댓글 쓰기
  8. YCCTEAM YCC-SW4001 Shoulder Buttons Replacement: 8 단계, 이미지 1개 중 1개
    • Remove the front case.
    댓글 쓰기
  9. YCCTEAM YCC-SW4001 Shoulder Buttons Replacement, Shoulder Buttons: 9 단계, 이미지 3개 중 1개 YCCTEAM YCC-SW4001 Shoulder Buttons Replacement, Shoulder Buttons: 9 단계, 이미지 3개 중 2개 YCCTEAM YCC-SW4001 Shoulder Buttons Replacement, Shoulder Buttons: 9 단계, 이미지 3개 중 3개
    • Flip over the front cover and remove the four 5.8 mm screws from the rear of the front cover using a Phillips screwdriver.
    댓글 쓰기
  10. YCCTEAM YCC-SW4001 Shoulder Buttons Replacement: 10 단계, 이미지 3개 중 1개 YCCTEAM YCC-SW4001 Shoulder Buttons Replacement: 10 단계, 이미지 3개 중 2개 YCCTEAM YCC-SW4001 Shoulder Buttons Replacement: 10 단계, 이미지 3개 중 3개
    • Flip up the ZIF locking flap.
    댓글 쓰기
  11. YCCTEAM YCC-SW4001 Shoulder Buttons Replacement: 11 단계, 이미지 2개 중 1개 YCCTEAM YCC-SW4001 Shoulder Buttons Replacement: 11 단계, 이미지 2개 중 2개
    • Disconnect the cable from the ZIF connector using tweezers or by hand.
    댓글 쓰기
  12. YCCTEAM YCC-SW4001 Shoulder Buttons Replacement: 12 단계, 이미지 2개 중 1개 YCCTEAM YCC-SW4001 Shoulder Buttons Replacement: 12 단계, 이미지 2개 중 2개
    • Remove the circuit board and shoulder buttons assembly from the front cover.
    댓글 쓰기
  13. YCCTEAM YCC-SW4001 Shoulder Buttons Replacement: 13 단계, 이미지 3개 중 1개 YCCTEAM YCC-SW4001 Shoulder Buttons Replacement: 13 단계, 이미지 3개 중 2개 YCCTEAM YCC-SW4001 Shoulder Buttons Replacement: 13 단계, 이미지 3개 중 3개
    • Remove the R button by hand.
    댓글 쓰기
  14. YCCTEAM YCC-SW4001 Shoulder Buttons Replacement: 14 단계, 이미지 3개 중 1개 YCCTEAM YCC-SW4001 Shoulder Buttons Replacement: 14 단계, 이미지 3개 중 2개 YCCTEAM YCC-SW4001 Shoulder Buttons Replacement: 14 단계, 이미지 3개 중 3개
    • Remove the L button by hand.
    • Flip the shoulder buttons attachment and look at the metal rods.
    댓글 쓰기
  15. YCCTEAM YCC-SW4001 Shoulder Buttons Replacement: 15 단계, 이미지 3개 중 1개 YCCTEAM YCC-SW4001 Shoulder Buttons Replacement: 15 단계, 이미지 3개 중 2개 YCCTEAM YCC-SW4001 Shoulder Buttons Replacement: 15 단계, 이미지 3개 중 3개
    • Remove the metal rod under "ZL" using the small needle nose pliers.
    댓글 쓰기
  16. YCCTEAM YCC-SW4001 Shoulder Buttons Replacement: 16 단계, 이미지 3개 중 1개 YCCTEAM YCC-SW4001 Shoulder Buttons Replacement: 16 단계, 이미지 3개 중 2개 YCCTEAM YCC-SW4001 Shoulder Buttons Replacement: 16 단계, 이미지 3개 중 3개
    • Remove the metal rod under "ZR" using small needle nose pliers.
    댓글 쓰기
  17. YCCTEAM YCC-SW4001 Shoulder Buttons Replacement: 17 단계, 이미지 3개 중 1개 YCCTEAM YCC-SW4001 Shoulder Buttons Replacement: 17 단계, 이미지 3개 중 2개 YCCTEAM YCC-SW4001 Shoulder Buttons Replacement: 17 단계, 이미지 3개 중 3개
    • Remove the ZL and ZR buttons by hand.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
2다른 기여자 명과 함께
Sam Borwick
회원 가입일: 02/15/24
333 평판
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 23
전체 시간: 425
