주요 콘텐츠로 건너뛰기
YCCTEAM YCC-SW4001 Shoulder Buttons Replacement
필요한 것
  1. YCCTEAM YCC-SW4001 Shoulder Buttons Replacement, Front Case: 1 단계, 이미지 1개 중 1개
    • Use a Phillips screwdriver to remove the eight 9.15 mm screws that secure the rear case.
  2. YCCTEAM YCC-SW4001 Shoulder Buttons Replacement: 2 단계, 이미지 3개 중 1개 YCCTEAM YCC-SW4001 Shoulder Buttons Replacement: 2 단계, 이미지 3개 중 2개 YCCTEAM YCC-SW4001 Shoulder Buttons Replacement: 2 단계, 이미지 3개 중 3개
    • Use an opening pick to pry the back cover off of the controller.
  3. YCCTEAM YCC-SW4001 Shoulder Buttons Replacement: 3 단계, 이미지 1개 중 1개
    • Use a Phillips screwdriver to remove the three 9.15 mm screws from the back of the controller.
  4. YCCTEAM YCC-SW4001 Shoulder Buttons Replacement: 4 단계, 이미지 3개 중 1개 YCCTEAM YCC-SW4001 Shoulder Buttons Replacement: 4 단계, 이미지 3개 중 2개 YCCTEAM YCC-SW4001 Shoulder Buttons Replacement: 4 단계, 이미지 3개 중 3개
    • Slightly lift the front case.
    • Do not remove the front cover completely; it is still attached to the motherboard by a white ribbon cable.
  5. YCCTEAM YCC-SW4001 Shoulder Buttons Replacement: 5 단계, 이미지 3개 중 1개 YCCTEAM YCC-SW4001 Shoulder Buttons Replacement: 5 단계, 이미지 3개 중 2개 YCCTEAM YCC-SW4001 Shoulder Buttons Replacement: 5 단계, 이미지 3개 중 3개
    • Use the tip of the opening pick to flip up the black locking flap of the ZIF connector.
    • The black flap holds the white ribbon cable in place.
  6. YCCTEAM YCC-SW4001 Shoulder Buttons Replacement: 6 단계, 이미지 2개 중 1개 YCCTEAM YCC-SW4001 Shoulder Buttons Replacement: 6 단계, 이미지 2개 중 2개
    • Use tweezers to disconnect the white ribbon cable from the ZIF connector.
  7. YCCTEAM YCC-SW4001 Shoulder Buttons Replacement: 7 단계, 이미지 1개 중 1개
    • Remove the front case.
  8. YCCTEAM YCC-SW4001 Shoulder Buttons Replacement, Shoulder Buttons: 8 단계, 이미지 3개 중 1개 YCCTEAM YCC-SW4001 Shoulder Buttons Replacement, Shoulder Buttons: 8 단계, 이미지 3개 중 2개 YCCTEAM YCC-SW4001 Shoulder Buttons Replacement, Shoulder Buttons: 8 단계, 이미지 3개 중 3개
    • Flip over the front cover and remove the four 5.8 mm screws from the rear of the front cover using a Phillips screwdriver.
  9. YCCTEAM YCC-SW4001 Shoulder Buttons Replacement: 9 단계, 이미지 3개 중 1개 YCCTEAM YCC-SW4001 Shoulder Buttons Replacement: 9 단계, 이미지 3개 중 2개 YCCTEAM YCC-SW4001 Shoulder Buttons Replacement: 9 단계, 이미지 3개 중 3개
    • Flip up the ZIF locking flap.
  10. YCCTEAM YCC-SW4001 Shoulder Buttons Replacement: 10 단계, 이미지 2개 중 1개 YCCTEAM YCC-SW4001 Shoulder Buttons Replacement: 10 단계, 이미지 2개 중 2개
    • Disconnect the cable from the ZIF connector using tweezers or by hand.
  11. YCCTEAM YCC-SW4001 Shoulder Buttons Replacement: 11 단계, 이미지 2개 중 1개 YCCTEAM YCC-SW4001 Shoulder Buttons Replacement: 11 단계, 이미지 2개 중 2개
    • Remove the circuit board and shoulder buttons assembly from the front cover.
  12. YCCTEAM YCC-SW4001 Shoulder Buttons Replacement: 12 단계, 이미지 3개 중 1개 YCCTEAM YCC-SW4001 Shoulder Buttons Replacement: 12 단계, 이미지 3개 중 2개 YCCTEAM YCC-SW4001 Shoulder Buttons Replacement: 12 단계, 이미지 3개 중 3개
    • Remove the R button by hand.
  13. YCCTEAM YCC-SW4001 Shoulder Buttons Replacement: 13 단계, 이미지 3개 중 1개 YCCTEAM YCC-SW4001 Shoulder Buttons Replacement: 13 단계, 이미지 3개 중 2개 YCCTEAM YCC-SW4001 Shoulder Buttons Replacement: 13 단계, 이미지 3개 중 3개
    • Remove the L button by hand.
    • Flip the shoulder buttons attachment and look at the metal rods.
  14. YCCTEAM YCC-SW4001 Shoulder Buttons Replacement: 14 단계, 이미지 3개 중 1개 YCCTEAM YCC-SW4001 Shoulder Buttons Replacement: 14 단계, 이미지 3개 중 2개 YCCTEAM YCC-SW4001 Shoulder Buttons Replacement: 14 단계, 이미지 3개 중 3개
    • Remove the metal rod under "ZL" using the small needle nose pliers.
  15. YCCTEAM YCC-SW4001 Shoulder Buttons Replacement: 15 단계, 이미지 3개 중 1개 YCCTEAM YCC-SW4001 Shoulder Buttons Replacement: 15 단계, 이미지 3개 중 2개 YCCTEAM YCC-SW4001 Shoulder Buttons Replacement: 15 단계, 이미지 3개 중 3개
    • Remove the metal rod under "ZR" using small needle nose pliers.
  16. YCCTEAM YCC-SW4001 Shoulder Buttons Replacement: 16 단계, 이미지 3개 중 1개 YCCTEAM YCC-SW4001 Shoulder Buttons Replacement: 16 단계, 이미지 3개 중 2개 YCCTEAM YCC-SW4001 Shoulder Buttons Replacement: 16 단계, 이미지 3개 중 3개
    • Remove the ZL and ZR buttons by hand.
결론
작성자
2다른 기여자 명과 함께
Sam Borwick
회원 가입일: 02/15/24
333 평판
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 20
전체 시간: 250
