주요 콘텐츠로 건너뛰기
YCCTEAM YCC-SW4001 Vibration Motor Replacement
필요한 것
  1. YCCTEAM YCC-SW4001 Vibration Motor Replacement, Front Case: 1 단계, 이미지 1개 중 1개
    • Use a Phillips screwdriver to remove the eight 9.15 mm screws that secure the rear case.
  2. YCCTEAM YCC-SW4001 Vibration Motor Replacement: 2 단계, 이미지 3개 중 1개 YCCTEAM YCC-SW4001 Vibration Motor Replacement: 2 단계, 이미지 3개 중 2개 YCCTEAM YCC-SW4001 Vibration Motor Replacement: 2 단계, 이미지 3개 중 3개
    • Use an opening pick to pry the back cover off of the controller.
  3. YCCTEAM YCC-SW4001 Vibration Motor Replacement: 3 단계, 이미지 1개 중 1개
    • Use a Phillips screwdriver to remove the three 9.15 mm screws from the back of the controller.
  4. YCCTEAM YCC-SW4001 Vibration Motor Replacement: 4 단계, 이미지 3개 중 1개 YCCTEAM YCC-SW4001 Vibration Motor Replacement: 4 단계, 이미지 3개 중 2개 YCCTEAM YCC-SW4001 Vibration Motor Replacement: 4 단계, 이미지 3개 중 3개
    • Slightly lift the front case.
    • Do not remove the front cover completely; it is still attached to the motherboard by a white ribbon cable.
  5. YCCTEAM YCC-SW4001 Vibration Motor Replacement: 5 단계, 이미지 3개 중 1개 YCCTEAM YCC-SW4001 Vibration Motor Replacement: 5 단계, 이미지 3개 중 2개 YCCTEAM YCC-SW4001 Vibration Motor Replacement: 5 단계, 이미지 3개 중 3개
    • Use the tip of the opening pick to flip up the black locking flap of the ZIF connector.
    • The black flap holds the white ribbon cable in place.
  6. YCCTEAM YCC-SW4001 Vibration Motor Replacement: 6 단계, 이미지 2개 중 1개 YCCTEAM YCC-SW4001 Vibration Motor Replacement: 6 단계, 이미지 2개 중 2개
    • Use tweezers to disconnect the white ribbon cable from the ZIF connector.
  7. YCCTEAM YCC-SW4001 Vibration Motor Replacement: 7 단계, 이미지 1개 중 1개
    • Remove the front case.
  8. YCCTEAM YCC-SW4001 Vibration Motor Replacement, Vibration Motor: 8 단계, 이미지 3개 중 1개 YCCTEAM YCC-SW4001 Vibration Motor Replacement, Vibration Motor: 8 단계, 이미지 3개 중 2개 YCCTEAM YCC-SW4001 Vibration Motor Replacement, Vibration Motor: 8 단계, 이미지 3개 중 3개
    • On the front side, disconnect the two vibration motor motherboard connectors.
    • Do not pull on the wires.
    • When replacing the rumble motors, press each plug down into its socket until it snaps into place.
  9. YCCTEAM YCC-SW4001 Vibration Motor Replacement: 9 단계, 이미지 3개 중 1개 YCCTEAM YCC-SW4001 Vibration Motor Replacement: 9 단계, 이미지 3개 중 2개 YCCTEAM YCC-SW4001 Vibration Motor Replacement: 9 단계, 이미지 3개 중 3개
    • Remove the rumble motors from the controller grips.
결론
작성자
3다른 기여자 명과 함께
David Adaway
회원 가입일: 02/16/24
537 평판
안내서 4개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 8
전체 시간: 154
