주요 콘텐츠로 건너뛰기
ZTE Maven 2 Screen Replacement
필요한 것
  1. ZTE Maven 2 Screen Replacement, Back Cover: 1 단계, 이미지 3개 중 1개 ZTE Maven 2 Screen Replacement, Back Cover: 1 단계, 이미지 3개 중 2개 ZTE Maven 2 Screen Replacement, Back Cover: 1 단계, 이미지 3개 중 3개
    • Pry off the back cover by inserting an opening tool into the small space on the bottom left between the phone's cover and body.
    • Work your way around the phone with an opening pick to loosen the rest of the back cover.
    • Remove the cover.
  2. ZTE Maven 2 Screen Replacement, Battery: 2 단계, 이미지 1개 중 1개
    • Push in and then up on the bottom of the battery to free it from its compartment.
    • Pull the battery out.
  3. ZTE Maven 2 Screen Replacement, MicroSD Card: 3 단계, 이미지 2개 중 1개 ZTE Maven 2 Screen Replacement, MicroSD Card: 3 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Using your fingers or blunt tweezers, carefully pull the memory card out of the slot.
    • A SIM card is used to demonstrate the process for removing the MicroSD card in these images.
  4. ZTE Maven 2 Screen Replacement, Midframe: 4 단계, 이미지 1개 중 1개
    • Remove the twelve 3 mm screws with a Phillips #00 screwdriver.
  5. ZTE Maven 2 Screen Replacement: 5 단계, 이미지 3개 중 1개 ZTE Maven 2 Screen Replacement: 5 단계, 이미지 3개 중 2개 ZTE Maven 2 Screen Replacement: 5 단계, 이미지 3개 중 3개
    • Wedge the opening tool between the front and side panel to create a gap.
    • Slide the opening pick around the device to detach the midframe.
  6. ZTE Maven 2 Screen Replacement, Motherboard: 6 단계, 이미지 3개 중 1개 ZTE Maven 2 Screen Replacement, Motherboard: 6 단계, 이미지 3개 중 2개 ZTE Maven 2 Screen Replacement, Motherboard: 6 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Peel the sticker off the battery compartment, as some of the motherboard components are hidden under it.
    • Remove the six 3 mm screws with a Phillips #00 screwdriver.
    • Using a pair of blunt tweezers, carefully remove the black wire that's attached to the gold plates on the left side of the device.
  7. ZTE Maven 2 Screen Replacement: 7 단계, 이미지 2개 중 1개 ZTE Maven 2 Screen Replacement: 7 단계, 이미지 2개 중 2개
    • Using the opening tool, carefully detach the ribbon cables connected to the motherboard.
  8. ZTE Maven 2 Screen Replacement: 8 단계, 이미지 2개 중 1개 ZTE Maven 2 Screen Replacement: 8 단계, 이미지 2개 중 2개
    • Work the opening pick around the edges of the motherboard to loosen it up.
    • The motherboard is glued down with adhesive. Pushing firmly with the pick will help to loosen the components and remove them.
    • Pull the motherboard out of the device.
  9. ZTE Maven 2 Screen Replacement, Daughterboard: 9 단계, 이미지 1개 중 1개
    • Remove the daughterboard containing the charging port.
  10. ZTE Maven 2 Screen Replacement, Screen: 10 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Detach the ribbon cable connecting the camera to the device.
    • Use blunt tweezers to pull the camera off.
    • What's left in your hands after removing the camera is the screen component. This is what gets replaced.
    • The screw holes for the midframe and motherboard overlap. Plan out which screws will go where.
결론
작성자
5다른 기여자 명과 함께
Hewot Takele
회원 가입일: 09/06/22
73 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 10
전체 시간: 295
