주요 콘텐츠로 건너뛰기
ZTE Prestige 2 Power and Volume Buttons Replacement
필요한 것
  1. ZTE Prestige 2 Power and Volume Buttons Replacement, Battery: 1 단계, 이미지 3개 중 1개 ZTE Prestige 2 Power and Volume Buttons Replacement, Battery: 1 단계, 이미지 3개 중 2개 ZTE Prestige 2 Power and Volume Buttons Replacement, Battery: 1 단계, 이미지 3개 중 3개
    • Use the iFixit opening tool to open up the device by wedging the tool under the back case and popping it open.
  2. ZTE Prestige 2 Power and Volume Buttons Replacement: 2 단계, 이미지 2개 중 1개 ZTE Prestige 2 Power and Volume Buttons Replacement: 2 단계, 이미지 2개 중 2개
    • Remove the battery.
  3. ZTE Prestige 2 Power and Volume Buttons Replacement, Back Panel: 3 단계, 이미지 3개 중 1개 ZTE Prestige 2 Power and Volume Buttons Replacement, Back Panel: 3 단계, 이미지 3개 중 2개 ZTE Prestige 2 Power and Volume Buttons Replacement, Back Panel: 3 단계, 이미지 3개 중 3개
    • Use a Phillips #00 screwdriver to unscrew all 12 of the 3 mm Phillips screws located along the edges of the device’s back panel, as well as the blue 3mm Phillips screw labeled “ZTE” located towards the top right.
  4. ZTE Prestige 2 Power and Volume Buttons Replacement: 4 단계, 이미지 3개 중 1개 ZTE Prestige 2 Power and Volume Buttons Replacement: 4 단계, 이미지 3개 중 2개 ZTE Prestige 2 Power and Volume Buttons Replacement: 4 단계, 이미지 3개 중 3개
    • Then use the iFixit opening tool and wedge it under the grey back panel and pop it off.
    • There will be a lot of resistance, apply adequate pressure.
  5. ZTE Prestige 2 Power and Volume Buttons Replacement, Power and Volume Buttons: 5 단계, 이미지 2개 중 1개 ZTE Prestige 2 Power and Volume Buttons Replacement, Power and Volume Buttons: 5 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use the curved tweezers to pull upwards and out on the the thin plastic attached on both sides of the power button and volume buttons. This process should allow the buttons to pop right out.
결론
작성자
4다른 기여자 명과 함께
Mackenzie Peterson
회원 가입일: 02/04/20
169 평판
안내서 2개를 작성함
UW Stout, Team S1-G4, Schneider-Bateman Spring 2020 UW Stout, Team S1-G4, Schneider-Bateman Spring 2020 회원
UWSTOUT-SCHNEIDER-BATEMAN-S20S1G4
3 회원들
안내서 14개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 6
전체 시간: 203
