주요 콘텐츠로 건너뛰기
ZTE Prestige 2 Speaker Replacement
필요한 것
  1. ZTE Prestige 2 Speaker Replacement, Battery: 1 단계, 이미지 1/3 ZTE Prestige 2 Speaker Replacement, Battery: 1 단계, 이미지 2/3 ZTE Prestige 2 Speaker Replacement, Battery: 1 단계, 이미지 3/3
    • Use the iFixit opening tool to open up the device by wedging the tool under the back case and popping it open.
  2. ZTE Prestige 2 Speaker Replacement: 2 단계, 이미지 1/2 ZTE Prestige 2 Speaker Replacement: 2 단계, 이미지 2/2
    • Remove the battery.
  3. ZTE Prestige 2 Speaker Replacement, Back Panel: 3 단계, 이미지 1/3 ZTE Prestige 2 Speaker Replacement, Back Panel: 3 단계, 이미지 2/3 ZTE Prestige 2 Speaker Replacement, Back Panel: 3 단계, 이미지 3/3
    • Use a Phillips #00 screwdriver to unscrew all 12 of the 3 mm Phillips screws located along the edges of the device’s back panel, as well as the blue 3mm Phillips screw labeled “ZTE” located towards the top right.
  4. ZTE Prestige 2 Speaker Replacement: 4 단계, 이미지 1/3 ZTE Prestige 2 Speaker Replacement: 4 단계, 이미지 2/3 ZTE Prestige 2 Speaker Replacement: 4 단계, 이미지 3/3
    • Then use the iFixit opening tool and wedge it under the grey back panel and pop it off.
    • There will be a lot of resistance, apply adequate pressure.
    • Use the Hakko 5B SA curved tweezers to dig under the top slit of the speaker and pull upwards.
  5. ZTE Prestige 2 Speaker Replacement: 6 단계, 이미지 1/2 ZTE Prestige 2 Speaker Replacement: 6 단계, 이미지 2/2
    • Use the curved tweezers to grab onto one of the corners of the speaker and pull upwards and lift out.
결론
Maria Stock
회원 가입일: 01/31/20
524 평판
안내서 5개 작성하였습니다
UW Stout, Team S1-G4, Schneider-Bateman Spring 2020 UW Stout, Team S1-G4, Schneider-Bateman Spring 2020 회원
UWSTOUT-SCHNEIDER-BATEMAN-S20S1G4
3 회원들
안내서 14개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 90
