주요 콘텐츠로 건너뛰기
ZTE Quest n817 Power/Volume Button Replacement
필요한 것
  1. ZTE Quest n817 Power/Volume Button Replacement, Battery: 1 단계, 이미지 3개 중 1개 ZTE Quest n817 Power/Volume Button Replacement, Battery: 1 단계, 이미지 3개 중 2개 ZTE Quest n817 Power/Volume Button Replacement, Battery: 1 단계, 이미지 3개 중 3개
    • Ensure that the phone is turned off before starting.
    • Orient the device so that the inset on the right side of the device is facing you.
    • Insert the spudger into the inset and carefully remove the back panel.
  2. ZTE Quest n817 Power/Volume Button Replacement: 2 단계, 이미지 2개 중 1개 ZTE Quest n817 Power/Volume Button Replacement: 2 단계, 이미지 2개 중 2개
    • Use the ribbon to remove the exposed battery.
  3. ZTE Quest n817 Power/Volume Button Replacement, Motherboard: 3 단계, 이미지 1개 중 1개
    • Use the JIS #000 screwdriver to remove the six 3.0mm screws placed in the back of the ZTE Quest.
  4. ZTE Quest n817 Power/Volume Button Replacement: 4 단계, 이미지 1개 중 1개
    • Carefully pry open the back panel with the plastic opening tool.
  5. ZTE Quest n817 Power/Volume Button Replacement: 5 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Use a pair of tweezers to gently disconnect the ribbon cable connector from its socket.
  6. ZTE Quest n817 Power/Volume Button Replacement: 6 단계, 이미지 1개 중 1개
    • Pull back the tape encasing the brown ribbon cable connector.
    • Remove the ribbon cable from its socket.
  7. ZTE Quest n817 Power/Volume Button Replacement: 7 단계, 이미지 1개 중 1개
    • Unplug the flat-top connector by using a pair of tweezers to pry up each side before removing the connector from its socket.
  8. ZTE Quest n817 Power/Volume Button Replacement: 8 단계, 이미지 2개 중 1개 ZTE Quest n817 Power/Volume Button Replacement: 8 단계, 이미지 2개 중 2개
    • Disconnect the coaxial connector in the bottom right corner of the motherboard.
  9. ZTE Quest n817 Power/Volume Button Replacement, Power/Volume Button: 9 단계, 이미지 1개 중 1개
    • Each of these buttons can be removed using micro-soldering techniques around either side of the button.
    • Instructions for how to do so can be found at iFixit's How to Solder and Desolder Connections guide.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Eric Loureiro
회원 가입일: 10/26/18
606 평판
안내서 5개를 작성함
UMass Dartmouth, Team S3-G6, Peak Fall 2018 UMass Dartmouth, Team S3-G6, Peak Fall 2018 회원
UMASSD-PEAK-F18S3G6
3 회원들
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 10
전체 시간: 390
