이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Orient the device so that the inset on the right side of the device is facing you.
Insert the spudger into the inset and carefully remove the back panel.
Use the JIS #000 screwdriver to remove the six 3.0mm screws placed in the back of the ZTE Quest.
Use a pair of tweezers to gently disconnect the ribbon cable connector from its socket.
Pull back the tape encasing the brown ribbon cable connector.
Remove the ribbon cable from its socket.
Unplug the flat-top connector by using a pair of tweezers to pry up each side before removing the connector from its socket.
Disconnect the coaxial connector in the bottom right corner of the motherboard.
Each of these buttons can be removed using micro-soldering techniques around either side of the button.
Instructions for how to do so can be found at iFixit's How to Solder and Desolder Connections guide.
다른 한 분이 해당 안내서를 완성하였습니다.
