주요 콘텐츠로 건너뛰기
Zebra ZP 450 Power Switch Replacement
필요한 것
  1. Zebra ZP 450 Power Switch Replacement, Motherboard: 1 단계, 이미지 1/1
    • Remove the three 12mm screws from the bottom of the printer using a Phillips #1 screwdriver.
    • Using the TR10 Torx screwdriver, remove the four 8mm screws from the bottom of the device.
  2. Zebra ZP 450 Power Switch Replacement: 2 단계, 이미지 1/1
    • Remove the single 7mm screw located underneath the outfeed using the same Phillips #1 screwdriver.
  3. Zebra ZP 450 Power Switch Replacement: 3 단계, 이미지 1/1
    • Using an opening pick, pry the plastic covering from around the power button and accessory ports.
  4. Zebra ZP 450 Power Switch Replacement: 4 단계, 이미지 1/3 Zebra ZP 450 Power Switch Replacement: 4 단계, 이미지 2/3 Zebra ZP 450 Power Switch Replacement: 4 단계, 이미지 3/3
    • After lifting the plastic casing from the device, use the Phillips #1 screwdriver to remove the single 5mm screw securing the motherboard.
    • Remove all connections to the motherboard.
  5. Zebra ZP 450 Power Switch Replacement, Power Switch: 5 단계, 이미지 1/1
    • Using the soldering iron, unsolder the joints on the back of the motherboard connecting the power switch to the motherboard.
    • For more information on proper soldering technique, please visit the How to Solder and Desolder Connections guide.
결론
Daniel Garmon
회원 가입일: 02/15/21
277 평판
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 7
전체 시간: 175
