주요 콘텐츠로 건너뛰기
Zeepad 7.0 Screen Replacement
필요한 것
  1. Zeepad 7.0 Screen Replacement, Screen: 1 단계, 이미지 1/2 Zeepad 7.0 Screen Replacement, Screen: 1 단계, 이미지 2/2
    • Power off the device and keep it unplugged.
    • Open the case using a plastic opening tool around the edges. Slightly pull the cover off.
    • Do not completely remove back casing because there is a speaker attached to the back.
  2. Zeepad 7.0 Screen Replacement: 2 단계, 이미지 1/1
    • Using the Phillips Head 0 bit, carefully unscrew the three 3.5mm screws holding the motherboard in place on to the back of the screen.
  3. Zeepad 7.0 Screen Replacement: 3 단계, 이미지 1/2 Zeepad 7.0 Screen Replacement: 3 단계, 이미지 2/2
    • Disconnect the two ribbon cables between the screen and the motherboard.
    • Be careful not to rip out the ribbon cables or you can harm the ports.
  4. Zeepad 7.0 Screen Replacement: 4 단계, 이미지 1/1
    • Cut the power cables connecting between the screen and the motherboard. There should be a red and black cable each.
  5. Zeepad 7.0 Screen Replacement: 5 단계, 이미지 1/2 Zeepad 7.0 Screen Replacement: 5 단계, 이미지 2/2
    • Separate the front screen protector from the lcd screen. There are clamps holding the screen in place.
  6. Zeepad 7.0 Screen Replacement: 6 단계, 이미지 1/3 Zeepad 7.0 Screen Replacement: 6 단계, 이미지 2/3 Zeepad 7.0 Screen Replacement: 6 단계, 이미지 3/3
    • Separate the LCD screen from the metal protecting case with the metal spudger.
  7. Zeepad 7.0 Screen Replacement: 7 단계, 이미지 1/3 Zeepad 7.0 Screen Replacement: 7 단계, 이미지 2/3 Zeepad 7.0 Screen Replacement: 7 단계, 이미지 3/3
    • After creating space to work, warm up a soldering iron.
    • Apply heat onto the solder over the corresponding cut wires to the new screen wires.
    • How To Solder and Desolder Connections
    • The soldering iron will be extremely hot. Keep out of direct contact to other wires, the motherboard, and especially the battery.
    • Keep out of reach of children.
결론
To reassemble your device, follow these instructions in order.
다른 한 분이 해당 안내서를 완성하였습니다.
Harry Winter
회원 가입일: 03/26/18
157 평판
안내서 1개 작성함
IUPUI, Team S2-G1, Harley Spring 2018 IUPUI, Team S2-G1, Harley Spring 2018 회원
IUPUI-HARLEY-S18S2G1
3 회원들
안내서 4개 작성하였습니다
댓글 2개
where do you buy the screen?
Zuzzi Z Amend - 답글
i need a battery an a screen? is their a place on this page where to get them?
Zuzzi Z Amend - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 4
전체 시간: 477
