주요 콘텐츠로 건너뛰기
Zeki TBQG884B Digitizer Touch Screen
필요한 것
  1. Zeki TBQG884B Digitizer Touch Screen, Rear Case: 1 단계, 이미지 2개 중 1개 Zeki TBQG884B Digitizer Touch Screen, Rear Case: 1 단계, 이미지 2개 중 2개
    • Remove the two screws from the end of the device where the ports are located using a Phillips #1 screwdriver.
  2. Zeki TBQG884B Digitizer Touch Screen: 2 단계, 이미지 1개 중 1개
    • Place the tablet down so that the screen is facing away from you.
    • Insert the tip of your opening tool into the small gap between the gray and white plastic covering. Pry it open and you should hear the clips opening up.
    • Gently work your way around the perimeter of the tablet's edge.
  3. Zeki TBQG884B Digitizer Touch Screen: 3 단계, 이미지 2개 중 1개 Zeki TBQG884B Digitizer Touch Screen: 3 단계, 이미지 2개 중 2개
    • Remove the back cover
    • Remove any tape on the speaker and detach the speaker from the back plate.
    • The speaker is connected to the motherboard by two soldered wires. Don't break them when you remove the speaker.
  4. Zeki TBQG884B Digitizer Touch Screen, Motherboard: 4 단계, 이미지 1개 중 1개
    • Disconnect the Wi-Fi antenna cable from the motherboard.
  5. Zeki TBQG884B Digitizer Touch Screen: 5 단계, 이미지 1개 중 1개
    • Using the Phillips #1 screwdriver, remove the three screws from the motherboard..
  6. Zeki TBQG884B Digitizer Touch Screen: 6 단계, 이미지 1개 중 1개
    • Open the ZIF connector. Then, remove the ribbon that connects the motherboard and the screen.
  7. Zeki TBQG884B Digitizer Touch Screen: 7 단계, 이미지 1개 중 1개
    • Disconnect the other ZIF connector on the opposite side of the motherboard.
  8. Zeki TBQG884B Digitizer Touch Screen: 8 단계, 이미지 1개 중 1개
    • Remove the motherboard and now reinsert all connectors into a new motherboard.
    • In order to disconnect the battery and speaker wires from the motherboard, soldering is required. Be cautious as the soldering iron is hot.
  9. Zeki TBQG884B Digitizer Touch Screen, LCD Screen: 9 단계, 이미지 1개 중 1개
    • Use an opening tool to detach the clip between the front frame, and the metal loader.
    • There are several clips on each side of the frame. Detach ALL of them before you open the loader.
  10. Zeki TBQG884B Digitizer Touch Screen: 10 단계, 이미지 1개 중 1개
    • Lift the metal loader up and separate it from the LCD screen.
    • Detach each piece slowly to avoid damaging or dropping any fragile parts.
  11. Zeki TBQG884B Digitizer Touch Screen, Digitizer Touch Screen: 11 단계, 이미지 1개 중 1개
    • Separate the display from the digitizer.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
9다른 기여자 명과 함께
David Wyman
회원 가입일: 09/16/15
346 평판
안내서 3개를 작성함
IUPUI, Team 1-3, Harley Fall 2015 IUPUI, Team 1-3, Harley Fall 2015 회원
IUPUI-HARLEY-F15S1G3
5 회원들
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 12
전체 시간: 937
