주요 콘텐츠로 건너뛰기
Zeki TBQG884B Motherboard Replacement
필요한 것
  1. Zeki TBQG884B Motherboard Replacement, Rear Case: 1 단계, 이미지 2개 중 1개 Zeki TBQG884B Motherboard Replacement, Rear Case: 1 단계, 이미지 2개 중 2개
    • Remove the two screws from the end of the device where the ports are located using a Phillips #1 screwdriver.
  2. Zeki TBQG884B Motherboard Replacement: 2 단계, 이미지 1개 중 1개
    • Place the tablet down so that the screen is facing away from you.
    • Insert the tip of your opening tool into the small gap between the gray and white plastic covering. Pry it open and you should hear the clips opening up.
    • Gently work your way around the perimeter of the tablet's edge.
  3. Zeki TBQG884B Motherboard Replacement: 3 단계, 이미지 2개 중 1개 Zeki TBQG884B Motherboard Replacement: 3 단계, 이미지 2개 중 2개
    • Remove the back cover
    • Remove any tape on the speaker and detach the speaker from the back plate.
    • The speaker is connected to the motherboard by two soldered wires. Don't break them when you remove the speaker.
  4. Zeki TBQG884B Motherboard Replacement, Motherboard: 4 단계, 이미지 1개 중 1개
    • Disconnect the Wi-Fi antenna cable from the motherboard.
  5. Zeki TBQG884B Motherboard Replacement: 5 단계, 이미지 1개 중 1개
    • Using the Phillips #1 screwdriver, remove the three screws from the motherboard..
  6. Zeki TBQG884B Motherboard Replacement: 6 단계, 이미지 1개 중 1개
    • Open the ZIF connector. Then, remove the ribbon that connects the motherboard and the screen.
  7. Zeki TBQG884B Motherboard Replacement: 7 단계, 이미지 1개 중 1개
    • Disconnect the other ZIF connector on the opposite side of the motherboard.
  8. Zeki TBQG884B Motherboard Replacement: 8 단계, 이미지 1개 중 1개
    • Remove the motherboard and now reinsert all connectors into a new motherboard.
    • In order to disconnect the battery and speaker wires from the motherboard, soldering is required. Be cautious as the soldering iron is hot.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
12다른 기여자 명과 함께
Linlin Cai
회원 가입일: 09/16/15
317 평판
안내서 1개를 작성함
IUPUI, Team 1-3, Harley Fall 2015 IUPUI, Team 1-3, Harley Fall 2015 회원
IUPUI-HARLEY-F15S1G3
5 회원들
안내서 5개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 1
전체 시간: 537
