이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
This is a guide for replacing the motherboard of your Zeki device. To reach the motherboard, first remove the plastic backing. Then, the battery, and camera. After replacing the motherboard, the device will need to be reassembled in the opposite order.
필요한 것
Remove the two screws from the end of the device where the ports are located using a Phillips #1 screwdriver.
Remove the Wi-Fi antenna element, which is highlighted by red in the picture, from the front plate.
다른 2명이 해당 안내서를 완성하였습니다.
