이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Remove the two screws from the end of the device where the ports are located using a Phillips #1 screwdriver.
Place the tablet down so that the screen is facing away from you.
Insert the tip of your opening tool into the small gap between the gray and white plastic covering. Pry it open and you should hear the clips opening up.
Gently work your way around the perimeter of the tablet's edge.
Remove the back cover
Remove any tape on the speaker and detach the speaker from the back plate.
Using the Phillips #1 screwdriver, remove the three screws from the motherboard..
Open the ZIF connector. Then, remove the ribbon that connects the motherboard and the screen.
Disconnect the other ZIF connector on the opposite side of the motherboard.
Remove the motherboard and now reinsert all connectors into a new motherboard.
다른 2명이 해당 안내서를 완성하였습니다.
