주요 콘텐츠로 건너뛰기
Zenbre SoundBank Z3 Battery Replacement
필요한 것
  1. Zenbre SoundBank Z3 Battery Replacement, Bottom Cover: 1 단계, 이미지 1/2 Zenbre SoundBank Z3 Battery Replacement, Bottom Cover: 1 단계, 이미지 2/2
    • Power off the SoundBank Z3.
    • Turn over the device.
    • Peel the silicone feet up to remove.
    • No extra adhesive is needed to reapply the feet as long as the sticky side is not touched.
  2. Zenbre SoundBank Z3 Battery Replacement: 2 단계, 이미지 1/1
    • Remove all eight of the 11 mm Phillips screws from the bottom of the device.
  3. Zenbre SoundBank Z3 Battery Replacement: 3 단계, 이미지 1/2 Zenbre SoundBank Z3 Battery Replacement: 3 단계, 이미지 2/2
    • Remove the bottom panel speaker using an iFixit opening tool.
  4. Zenbre SoundBank Z3 Battery Replacement, Motherboard Cover: 4 단계, 이미지 1/3 Zenbre SoundBank Z3 Battery Replacement, Motherboard Cover: 4 단계, 이미지 2/3 Zenbre SoundBank Z3 Battery Replacement, Motherboard Cover: 4 단계, 이미지 3/3
    • Remove the four 4.5 mm silver Phillips screws that secure the plastic panel covering the motherboard.
    • Remove the plastic panel.
  5. Zenbre SoundBank Z3 Battery Replacement, Battery: 5 단계, 이미지 1/2 Zenbre SoundBank Z3 Battery Replacement, Battery: 5 단계, 이미지 2/2
    • Remove the battery from the holder. It may be difficult the first time.
    • Use a spudger between the battery and speaker wall to loosen it from its surroundings.
    • If the battery is punctured, leaking, or bloated/puffy, it may be hazardous and should be properly disposed of.
  6. Zenbre SoundBank Z3 Battery Replacement: 6 단계, 이미지 1/2 Zenbre SoundBank Z3 Battery Replacement: 6 단계, 이미지 2/2
    • Remove the pressure-fitted foam from the slot by hand.
    • Unravel and remove foam from the wires.
    • When reassembling, the foam can be re-wrapped if care is taken when handling it.
  7. Zenbre SoundBank Z3 Battery Replacement: 7 단계, 이미지 1/1
    • Using a soldering iron, remove the leads, separating the battery from motherboard.
    • Follow this guide to help you remove the wires from the motherboard if you are unfamiliar with soldering.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Cherian Thomas
회원 가입일: 03/25/16
334 평판
안내서 5개 작성하였습니다
UMass Dartmouth, Team 3-2, Bhusal Spring 2016 UMass Dartmouth, Team 3-2, Bhusal Spring 2016 회원
UMASSD-BHUSAL-S16S3G2
5 회원들
안내서 8개 작성하였습니다
댓글 3개
Thank you for providing battery replacement instructions for the ZENGRE BlueTooth speaker system. They are very helpful.
Michael Coleman - 답글
Bendiciones. con que batería la reemplazaste? podrías enviarme un link para comprarlo, desde ya muchas gracias
Alier Obed Jaenz Rivas -
MUCHAS GRACIAS!!!!
Sin embargo hubiese sido exelente pudiese mostrarse los tipos de batería con los cuales se puede reemplazar.
Alier Obed Jaenz Rivas - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 15
전체 시간: 4,580
