주요 콘텐츠로 건너뛰기
Zenbre SoundBank Z3 Speaker Replacement
필요한 것
  1. Zenbre SoundBank Z3 Speaker Replacement, Bottom Cover: 1 단계, 이미지 1/2 Zenbre SoundBank Z3 Speaker Replacement, Bottom Cover: 1 단계, 이미지 2/2
    • Power off the SoundBank Z3.
    • Turn over the device.
    • Peel the silicone feet up to remove.
    • No extra adhesive is needed to reapply the feet as long as the sticky side is not touched.
  2. Zenbre SoundBank Z3 Speaker Replacement: 2 단계, 이미지 1/1
    • Remove all eight of the 11 mm Phillips screws from the bottom of the device.
  3. Zenbre SoundBank Z3 Speaker Replacement: 3 단계, 이미지 1/2 Zenbre SoundBank Z3 Speaker Replacement: 3 단계, 이미지 2/2
    • Remove the bottom panel speaker using an iFixit opening tool.
  4. Zenbre SoundBank Z3 Speaker Replacement, Motherboard Cover: 4 단계, 이미지 1/3 Zenbre SoundBank Z3 Speaker Replacement, Motherboard Cover: 4 단계, 이미지 2/3 Zenbre SoundBank Z3 Speaker Replacement, Motherboard Cover: 4 단계, 이미지 3/3
    • Remove the four 4.5 mm silver Phillips screws that secure the plastic panel covering the motherboard.
    • Remove the plastic panel.
  5. Zenbre SoundBank Z3 Speaker Replacement, Speakers: 5 단계, 이미지 1/2 Zenbre SoundBank Z3 Speaker Replacement, Speakers: 5 단계, 이미지 2/2
    • Remove the three screws that are holding the speaker down.
    • Be careful not to rip out the speaker while taking out the screws.
  6. Zenbre SoundBank Z3 Speaker Replacement: 6 단계, 이미지 1/2 Zenbre SoundBank Z3 Speaker Replacement: 6 단계, 이미지 2/2
    • Desolder the speaker joints from the motherboard. Follow this How To Solder guide for help with desoldering.
  7. Zenbre SoundBank Z3 Speaker Replacement: 7 단계, 이미지 1/2 Zenbre SoundBank Z3 Speaker Replacement: 7 단계, 이미지 2/2
    • Remove the speaker from the motherboard.
    • Remove the speaker ring.
    • Be careful not to remove other components in the speaker.
    • Repeat Steps 5-7 with the other speaker.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Cherian Thomas
회원 가입일: 03/25/16
334 평판
안내서 5개 작성하였습니다
UMass Dartmouth, Team 3-2, Bhusal Spring 2016 UMass Dartmouth, Team 3-2, Bhusal Spring 2016 회원
UMASSD-BHUSAL-S16S3G2
5 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 14
전체 시간: 473
