주요 콘텐츠로 건너뛰기
Zoomer Dino Boomer Main Circuit Board Replacement
필요한 것
  1. Zoomer Dino Boomer Main Circuit Board Replacement, Back Cover: 1 단계, 이미지 1/1
    • Power off Zoomer Dino Boomer before disassembly.
    • Remove the eight 9.3mm Phillips #1 screws.
  2. Zoomer Dino Boomer Main Circuit Board Replacement: 2 단계, 이미지 1/2 Zoomer Dino Boomer Main Circuit Board Replacement: 2 단계, 이미지 2/2
    • Turn dinosaur over and hold upright.
    • Use the spudger to pry apart the back cover from the remainder of the Zoomer Dino Boomer.
    • Be gentle while removing the back cover. The back cover of the Zoomer Dino Boomer is still connected to the electronic system by a wire.
  3. Zoomer Dino Boomer Main Circuit Board Replacement: 3 단계, 이미지 1/3 Zoomer Dino Boomer Main Circuit Board Replacement: 3 단계, 이미지 2/3 Zoomer Dino Boomer Main Circuit Board Replacement: 3 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Disconnect the wire that connects the back cover of the dino to the main circuit board by carefully pulling on the orange wire connector with tweezers.
    • Remove back cover.
    • If you are having difficulty removing the connector from its socket, push in the small tabs on the side of the connector with the tweezers. This step may take some work.
    • Do not damage the wires or circuit board.
  4. Zoomer Dino Boomer Main Circuit Board Replacement, Main Circuit Board: 4 단계, 이미지 1/3 Zoomer Dino Boomer Main Circuit Board Replacement, Main Circuit Board: 4 단계, 이미지 2/3 Zoomer Dino Boomer Main Circuit Board Replacement, Main Circuit Board: 4 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Use tweezers to remove all of the colored wire connectors from their sockets on the circuit board.
  5. Zoomer Dino Boomer Main Circuit Board Replacement: 5 단계, 이미지 1/2 Zoomer Dino Boomer Main Circuit Board Replacement: 5 단계, 이미지 2/2
    • Remove legs.
  6. Zoomer Dino Boomer Main Circuit Board Replacement: 6 단계, 이미지 1/1
    • Remove the three 7.2 mm Phillips #0 screws connecting the main circuit board to the body of Zoomer Dino Boomer.
  7. Zoomer Dino Boomer Main Circuit Board Replacement: 7 단계, 이미지 1/3 Zoomer Dino Boomer Main Circuit Board Replacement: 7 단계, 이미지 2/3 Zoomer Dino Boomer Main Circuit Board Replacement: 7 단계, 이미지 3/3
    • Use soldering iron and tweezers to disconnect main circuit board from the black and red wires.
    • Check out iFixit's soldering techniques guide to learn more about soldering and desoldering connections.
    • Remove main circuit board from Zoomer Dino Boomer
결론
다른 5명이 해당 안내서를 완성하였습니다.
Desiree DesJardins
회원 가입일: 09/02/15
452 평판
안내서 2개 작성하였습니다
USF Tampa, Team 16-1, Wollert Fall 2015 USF Tampa, Team 16-1, Wollert Fall 2015 회원
USFT-WOLLERT-F15S16G1
3 회원들
안내서 10개 작성하였습니다
댓글 4개
can anyone tell me where to get a replacement motherboard?
alan.scott - 답글
Nah cuz my dino doesn't show any life support at all just the controller and Idek what's the issue. If this is the way to solve it be so for real tell me where to get that new circuit.
Nightmare_Requiem - 답글
The batteries location?
Tony Beatenbo - 답글
Is there a way to look at the dinosaurs code?
In other words, how it runs?
I´m having one for 5 years now and would like to create a digital copy.
It´s a private project and i alrerady finished the 3D Model.
If you know anything about this topic or someone familiar with that, please reply.
Thank you in advance
Blend Craft - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 6
30일 전: 22
전체 시간: 4,512
