주요 콘텐츠로 건너뛰기
Zoomer Dino Boomer Nose Sensor Replacement
필요한 것
  1. Zoomer Dino Boomer Nose Sensor Replacement, Nose Sensor: 1 단계, 이미지 1/2 Zoomer Dino Boomer Nose Sensor Replacement, Nose Sensor: 1 단계, 이미지 2/2
    • Unscrew the two 7.5 mm Phillips #0 screws at the base of the neck.
    • Remove the two 7.2 mm Phillips #0 screws above these at the base of the mouth.
  2. Zoomer Dino Boomer Nose Sensor Replacement: 2 단계, 이미지 1/2 Zoomer Dino Boomer Nose Sensor Replacement: 2 단계, 이미지 2/2
    • Use the spudger to pry Zoomer Dino Boomer's lower jaw from its mouth.
  3. Zoomer Dino Boomer Nose Sensor Replacement: 3 단계, 이미지 1/2 Zoomer Dino Boomer Nose Sensor Replacement: 3 단계, 이미지 2/2
    • Remove the roof of Zoomer Dino Boomer's mouth by unscrewing the 7.5 mm Phillips #0 screw.
  4. Zoomer Dino Boomer Nose Sensor Replacement: 4 단계, 이미지 1/2 Zoomer Dino Boomer Nose Sensor Replacement: 4 단계, 이미지 2/2
    • Carefully push the sensors out of the nose socket with your fingers.
  5. Zoomer Dino Boomer Nose Sensor Replacement: 5 단계, 이미지 1/3 Zoomer Dino Boomer Nose Sensor Replacement: 5 단계, 이미지 2/3 Zoomer Dino Boomer Nose Sensor Replacement: 5 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Use a soldering iron to remove the wires from the sensor chip by melting the metal joints on the chip.
    • Use the tweezers to remove the wires as you are soldering them.
    • Do not touch any parts of Zoomer Dino Boomer or yourself when using the soldering iron. The soldering iron will be very hot.
    • When reassembling, extra solder may be required to reconnect the wires with the circuit board.
  6. Zoomer Dino Boomer Nose Sensor Replacement: 6 단계, 이미지 1/1
    • Remove and replace the nose sensor.
결론
Lauren Mannix
회원 가입일: 08/29/15
398 평판
안내서 3개 작성하였습니다
USF Tampa, Team 16-1, Wollert Fall 2015 USF Tampa, Team 16-1, Wollert Fall 2015 회원
USFT-WOLLERT-F15S16G1
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 9
전체 시간: 1,370
