주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Zyllion ZMA-13-BK Shiatsu Massage Pillow Heater Replacement
필요한 것
  1. Zyllion ZMA-13-BK Shiatsu Massage Pillow Heater Replacement, Heater: 1 단계, 이미지 2개 중 1개 Zyllion ZMA-13-BK Shiatsu Massage Pillow Heater Replacement, Heater: 1 단계, 이미지 2개 중 2개
    • Disconnect the power plug located on the back of the massage pillow.
    • Please do this step carefully in order to avoid electric shock.
  2. Zyllion ZMA-13-BK Shiatsu Massage Pillow Heater Replacement: 2 단계, 이미지 2개 중 1개 Zyllion ZMA-13-BK Shiatsu Massage Pillow Heater Replacement: 2 단계, 이미지 2개 중 2개
    • Unzip the cover. You can locate the zipper at the back of the massage pillow.
    • Take out the pillow so that you can manage the heater completely.
  3. Zyllion ZMA-13-BK Shiatsu Massage Pillow Heater Replacement: 3 단계, 이미지 1개 중 1개
    • Use a Phillips JIS #1 screwdriver to remove the screw at the center of the heater.
    • The screw is 8.0mm.
  4. Zyllion ZMA-13-BK Shiatsu Massage Pillow Heater Replacement: 4 단계, 이미지 2개 중 1개 Zyllion ZMA-13-BK Shiatsu Massage Pillow Heater Replacement: 4 단계, 이미지 2개 중 2개
    • Remove the entire heater from the pillow.
    • You can see a green circuit board after removing the heater.
  5. Zyllion ZMA-13-BK Shiatsu Massage Pillow Heater Replacement: 5 단계, 이미지 1개 중 1개
    • Using the Phillips JIS #1 screwdriver, remove the three screws circled in the picture.
    • All three screws are 8.0mm, which are the same size as the previous one. They are interchangeable.
  6. Zyllion ZMA-13-BK Shiatsu Massage Pillow Heater Replacement: 6 단계, 이미지 1개 중 1개
    • Now you can take out the circuit board. There will be two wires attached to the circuit board.
    • If you prefer, you can clean the circuit board gently with dry tissues to remove the sticky lubricant.
  7. Zyllion ZMA-13-BK Shiatsu Massage Pillow Heater Replacement: 7 단계, 이미지 1개 중 1개
    • Use the pry bar to separate the wire from the white main board.
    • Before prying, check if you removed the power plug from the outlet and the massage pillow.
  8. Zyllion ZMA-13-BK Shiatsu Massage Pillow Heater Replacement: 8 단계, 이미지 1개 중 1개
    • Using your soldering station, remove the wires from the circuit board.
    • If you don't know how to solder, you can check out this guide: How To Solder and Desolder Connections
    • Soldering can be dangerous. Be cautious of high heat soldering tools.
    • Now, you can separate the circuit board completely to replace with a new heater.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Yuchen Li
회원 가입일: 09/28/15
125 평판
안내서 1개를 작성함
Cal Poly, Team 14-2, Green Fall 2015 Cal Poly, Team 14-2, Green Fall 2015 회원
CPSU-GREEN-F15S14G2
4 회원들
안내서 9개를 작성함
2가이드 댓글
Hi YuChen, nice work! Do you know from where I can find the switch for this heater? If you can tell me the part number, I can try looking it up on eBay. Thanks!
Abhishek Srivastava - 답글 공유
YuChen, by any chance do you know where I can get the whole covering of this Shiatsu Massage Pillow. The fabric of mine has deteriorated and torn off. I have been trying to find one using Google search but was unable to find. Can you help, Thank you
gamesake2 - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 79
전체 시간: 6,995
