소개
This is where all of the power comes into the device. Learn how to replace it. Be careful while soldering!
필요한 것
Remove the rubber foot pads on the bottom of the device using a plastic opening tool.
Locate the three solder connections for the electrical port.
Desolder the connection points following the instructions included with your soldering kit as you remove the port.
다른 한 분이 해당 안내서를 완성하였습니다.
