소개
Change out the entire display assembly, including the inverter, AirPort antenna, hinges and plastic casing.
Use a coin to rotate the battery locking screw 90 degrees clockwise.
Lift the battery out of the computer.
Pull the keyboard release tabs (shown in yellow) toward you and lift up on the keyboard until it pops free.
If the keyboard does not come free, use a small flathead screwdriver to turn the keyboard locking screw (shown in orange) 180 degrees in either direction and try again.
Flip the keyboard over, away from the screen, and rest it face-down on the trackpad area.
Close the display and flip the computer over.
Remove the three hex screws using a T8 Torx screwdriver.
Remove the following 10 screws from the bottom shield:
Six 3 mm Phillips
Three 7.5 mm Phillips
One 14 mm Phillips
Remove the following 11 screws from the bottom of the computer:
Three 3 mm Phillips around the battery compartment.
Three 4.5 mm Phillips along the optical drive bezel. (a magnetic screwdriver may help to lift these screws out)
One 12 mm Phillips in the lower right corner.
Four 14.5 mm Phillips.
Remove the following 16 screws:
Thirteen 3 mm Phillips.
One 3 mm Phillips.
Two 4 mm Phillips.
Remove the two Phillips screws at the corners of the modem.
Remove the three 3 mm Phillips screws securing the AirPort card bracket to the framework.
Lift the AirPort card bracket up and out of the computer.
다른 14명이 해당 안내서를 완성하였습니다.
첨부 문서
댓글 2개
Smooth as silk Walter. I am changing this to try and address a Black screen problem. After a Optical Drive and HD (OWC Legacy SSD) my machine went from perfect to normal boot then 28-30 secs later, black screen while everything else worked (caps lock light, pulsing sleep light, etc.) Will let you know if this solved the prob as I have a screen harvested years ago from a working iBook of mine.
Thanks
Nothing yet Walter. The past couple of weeks I have dismantled my iBook 14” 1.42 and put it back together a half dozen times or so. I’ve bought parts off of ebay, harvested stuff from my spare iBook and I am certain of this... It still loads as normal as can be. Bright screen, sound, etc. but 38 secs from first desktop view and 28-30 secs after complete load it gets a black screen.
I’ve checked or replaced: RAM, Inverter cable, HD, different display, and more. I’ve tried rushing to the sys prefs and setting it to “no sleep.” I’ve quickly opened a song in Quicktime and it shuts off with the screen goes black.
Any other suggestions from anyone would be great. I really dig my iBook and it was working fine until I replaced the Optical drive (now gone) and at one point I started it up with only the aluminum shields on and it worked fine. Then, after putting the cases back together, nothing since.
