주요 콘텐츠로 건너뛰기
iHip Fold-up Portable Speaker Replacement
필요한 것
  1. iHip Fold-up Portable Speaker Replacement, Removing the battery case cover: 1 단계, 이미지 1/1
    • Use your fingers to slide the battery case cover off in the direction of the arrows.
  2. iHip Fold-up Portable Speaker Replacement, Cleaning the battery case: 2 단계, 이미지 1/3 iHip Fold-up Portable Speaker Replacement, Cleaning the battery case: 2 단계, 이미지 2/3 iHip Fold-up Portable Speaker Replacement, Cleaning the battery case: 2 단계, 이미지 3/3
    • Remove the four AAA batteries. Be sure to check your nearest battery recycling point!
    • Use the detailing brush and a paper towel to remove any corrosion left by previous batteries.
  3. iHip Fold-up Portable Speaker Replacement, Removing the screws: 3 단계, 이미지 1/2 iHip Fold-up Portable Speaker Replacement, Removing the screws: 3 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Unscrew the four outer 1.0 mm screws with a Phillips-Head screwdriver.
    • Screws will be magnetized in position and will require the use of tweezers to be removed.
    • Push down gently on the battery case cover and slide it in the direction the arrows indicate. Remove the batteries.
    • Unscrew the 0.6 mm screw located in the center of the battery case.
    • Keep the 1.0 mm and 0.6 mm screws separate from each other for reassembly.
  4. iHip Fold-up Portable Speaker Replacement, Removing the back cover: 4 단계, 이미지 1/2 iHip Fold-up Portable Speaker Replacement, Removing the back cover: 4 단계, 이미지 2/2
    • Remove the back cover carefully; there are many wires that connect it to the device.
  5. iHip Fold-up Portable Speaker Replacement, Locating Speakers: 5 단계, 이미지 1/1
    • Locate the two individual speakers on either side of the front cover.
  6. iHip Fold-up Portable Speaker Replacement, Removing Individual Speakers: 6 단계, 이미지 1/3 iHip Fold-up Portable Speaker Replacement, Removing Individual Speakers: 6 단계, 이미지 2/3 iHip Fold-up Portable Speaker Replacement, Removing Individual Speakers: 6 단계, 이미지 3/3
    • Use a plastic opening tool to scrape off the glue around the speakers.
    • Gently pull the speaker up to detach it from the front cover.
    • Desolder the black and red wires from the speaker unit.
    • Use a hot glue gun to secure the new speaker. Solder the black and red speaker wires back in place.
결론
Lisa
회원 가입일: 10/13/14
207 평판
안내서 2개 작성하였습니다
Clemson, Team 3-4, Benson Fall 2014 Clemson, Team 3-4, Benson Fall 2014 회원
CLEM-BENSON-F14S3G4
5 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 7
전체 시간: 730
