주요 콘텐츠로 건너뛰기
iHome IH11 Control Buttons Replacement
필요한 것
  1. iHome IH11 Control Buttons Replacement, Outer Case: 1 단계, 이미지 1/1
    • Unscrew the two 9.0 mm screws with the Phillips #1 screwdriver.
    • Remove the translucent bottom case.
  2. iHome IH11 Control Buttons Replacement: 2 단계, 이미지 1/2 iHome IH11 Control Buttons Replacement: 2 단계, 이미지 2/2
    • Remove the two 9.0mm screws on the back of the iHome with the Phillips #1 screwdriver.
    • Repeat the previous step for the two screws on the bottom.
  3. iHome IH11 Control Buttons Replacement: 3 단계, 이미지 1/1
    • Remove the two 9mm screws from the top of the iHome with a Phillips #1 Screwdriver.
  4. iHome IH11 Control Buttons Replacement: 4 단계, 이미지 1/1
    • Pop the dock connector out of the iHome and gently pull the white plastic plug from the dock connector.
  5. iHome IH11 Control Buttons Replacement: 5 단계, 이미지 1/1
    • Carefully pull apart the device.
    • Remove the four screws that hold the circuit board for the buttons.
  6. iHome IH11 Control Buttons Replacement: 6 단계, 이미지 1/1
    • Desolder the four connections for the broken button.
    • Solder the new button in the place of the old one.
    • For more information about soldering, refer to the soldering device page. Soldering Skills
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Courtney Steinberg
회원 가입일: 04/19/13
35 평판
안내서 3개 작성하였습니다
Cal Poly, Team 14-9, Maness Spring 2013 Cal Poly, Team 14-9, Maness Spring 2013 회원
CPSU-MANESS-S13S14G9
5 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 9
전체 시간: 353
