주요 콘텐츠로 건너뛰기
iHome IH11 Dock Connector Replacement
필요한 것
  1. iHome IH11 Dock Connector Replacement, Dock Connector: 1 단계, 이미지 1/1
    • Remove the two 9mm screws that hold on the dock connector with a Phillips #1 Screwdriver.
  2. iHome IH11 Dock Connector Replacement: 2 단계, 이미지 1/2 iHome IH11 Dock Connector Replacement: 2 단계, 이미지 2/2
    • Pop the dock connector out of the iHome and gently pull the white plastic plug connected to the dock connector apart.
    • Remove the four 7.0mm screws with a Phillips #1 screwdriver.
  3. iHome IH11 Dock Connector Replacement: 3 단계, 이미지 1/1
    • Remove both of the black plastic pieces. They should easily slide off of the two guide holes in the circuit board.
    • The dock connector should now be exposed. You can now simply put your new dock connector in the old one's place.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Nick Knowles
회원 가입일: 04/19/13
21 평판
안내서 2개 작성하였습니다
Cal Poly, Team 14-9, Maness Spring 2013 Cal Poly, Team 14-9, Maness Spring 2013 회원
CPSU-MANESS-S13S14G9
5 회원들
안내서 5개 작성하였습니다
댓글 2개
Where can I buy a replacement dock connector?
A Ross - 답글
Likewise, this guide isn't much good if it uses parts that are unavailable.
CJ Shumate - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 9
전체 시간: 2,414
