주요 콘텐츠로 건너뛰기
iHome IH11 Main Motherboard Replacement
필요한 것
  1. iHome IH11 Main Motherboard Replacement, Outer Case: 1 단계, 이미지 1/1
    • Unscrew the two 9.0 mm screws with a Phillips #1 screwdriver.
    • Remove the translucent bottom case.
  2. iHome IH11 Main Motherboard Replacement: 2 단계, 이미지 1/2 iHome IH11 Main Motherboard Replacement: 2 단계, 이미지 2/2
    • Remove the two Phillips #1 9.0mm screws on the back of the iHome.
    • Repeat the previous step for the two 9.0mm screws on the bottom.
    • Carefully slide the back cover off. There are wires connected to the back cover.
  3. iHome IH11 Main Motherboard Replacement: 3 단계, 이미지 1/1
    • Remove the aluminum bracket by loosening the two nuts and removing the 8.0 mm bolts.
    • Pull the bracket out.
  4. iHome IH11 Main Motherboard Replacement: 4 단계, 이미지 1/2 iHome IH11 Main Motherboard Replacement: 4 단계, 이미지 2/2
    • Remove the two 12.0mm screws that hold the motherboard with a Phillips #1 screwdriver.
    • Slide the motherboard gently out.
  5. iHome IH11 Main Motherboard Replacement: 5 단계, 이미지 1/1
    • Solder each wire to corresponding input on the motherboard.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Courtney Steinberg
회원 가입일: 04/19/13
35 평판
안내서 3개 작성하였습니다
Cal Poly, Team 14-9, Maness Spring 2013 Cal Poly, Team 14-9, Maness Spring 2013 회원
CPSU-MANESS-S13S14G9
5 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 370
