소개
This guide will show you how to disassemble and remove the speakers in the iHome iAVS16, we hope you can use our guide to help you.
필요한 것
Remove the four 1.7 mm Phillips #0 screws located on the bottom of the device.
Lift up the bottom of the device.
Insert an iFixit opening tool into the lining on the front casing and pry it apart. Do this for both sides.
Further remove the front casing off from the device manually with your hands.
Using an iFixit opening tool, push the tab under the top of the device to create a gap.
Insert the iFixit opening tool in the gap, and slide it across to remove the top casing.
Remove the four Phillips screws on the back of the front half of the device holding the speakers in.
Push the speakers out of the back of the device.
Thank you for using our guide, we hope that it helped you fix your project
