주요 콘텐츠로 건너뛰기
iHome iAVS16 Wi-Fi Antenna Replacement
필요한 것
  1. iHome iAVS16 Wi-Fi Antenna Replacement, Power Board: 1 단계, 이미지 1/3 iHome iAVS16 Wi-Fi Antenna Replacement, Power Board: 1 단계, 이미지 2/3 iHome iAVS16 Wi-Fi Antenna Replacement, Power Board: 1 단계, 이미지 3/3
    • Remove the four 1.7 mm Phillips #0 screws located on the bottom of the device.
    • Lift up the bottom of the device.
    • Carefully lift the bottom of the device up as to not damage the ribbon cable connecting it.
  2. iHome iAVS16 Wi-Fi Antenna Replacement: 2 단계, 이미지 1/3 iHome iAVS16 Wi-Fi Antenna Replacement: 2 단계, 이미지 2/3 iHome iAVS16 Wi-Fi Antenna Replacement: 2 단계, 이미지 3/3
    • Remove the two 1.7 mm Phillips #0 screws holding the white face place onto the inside of the device's bottom.
    • Using an iFixit opening tool on the side without the black adhesive, carefully lift up the white face plate.
    • Lifting too quickly could damage the ribbon cable still attached.
  3. iHome iAVS16 Wi-Fi Antenna Replacement: 3 단계, 이미지 1/2 iHome iAVS16 Wi-Fi Antenna Replacement: 3 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Using the tweezers, lift up on the black tab holding the ribbon cable down.
    • Carefully pull the ribbon cable back and out of the slot.
  4. iHome iAVS16 Wi-Fi Antenna Replacement: 4 단계, 이미지 1/3 iHome iAVS16 Wi-Fi Antenna Replacement: 4 단계, 이미지 2/3 iHome iAVS16 Wi-Fi Antenna Replacement: 4 단계, 이미지 3/3
    • Remove the two 1.7 mm Phillips #0 screws holding the power board in.
    • Carefully flip the board over.
    • Remove the red connector from its socket with a pair of tweezers.
  5. iHome iAVS16 Wi-Fi Antenna Replacement, LCD (Display): 5 단계, 이미지 1/3 iHome iAVS16 Wi-Fi Antenna Replacement, LCD (Display): 5 단계, 이미지 2/3 iHome iAVS16 Wi-Fi Antenna Replacement, LCD (Display): 5 단계, 이미지 3/3
    • Insert an iFixit opening tool into the lining on the front casing and pry it apart. Do this for both sides.
    • Further remove the front casing off from the device manually with your hands.
  6. iHome iAVS16 Wi-Fi Antenna Replacement: 6 단계, 이미지 1/1
    • Remove the four 1.7 mm Phillips #0 screws holding the LCD onto the front of the device.
  7. iHome iAVS16 Wi-Fi Antenna Replacement: 7 단계, 이미지 1/3 iHome iAVS16 Wi-Fi Antenna Replacement: 7 단계, 이미지 2/3 iHome iAVS16 Wi-Fi Antenna Replacement: 7 단계, 이미지 3/3
    • Carefully flip the LCD display over to expose the ribbon cable connecting it.
    • Lift the black tab holding the cable down, and carefully put it out of the socket.
  8. iHome iAVS16 Wi-Fi Antenna Replacement, Wi-Fi Antenna: 8 단계, 이미지 1/3 iHome iAVS16 Wi-Fi Antenna Replacement, Wi-Fi Antenna: 8 단계, 이미지 2/3 iHome iAVS16 Wi-Fi Antenna Replacement, Wi-Fi Antenna: 8 단계, 이미지 3/3
    • Using an iFixit opening tool, push the tab under the top of the device to create a gap.
    • Sometimes the top will pop off easily, and other times it will not. You may need to hold the tab up while you insert the iFixit opening tool under the top lining.
    • Insert the iFixit opening tool in the gap, and slide it across to remove the top casing.
  9. iHome iAVS16 Wi-Fi Antenna Replacement: 9 단계, 이미지 1/3 iHome iAVS16 Wi-Fi Antenna Replacement: 9 단계, 이미지 2/3 iHome iAVS16 Wi-Fi Antenna Replacement: 9 단계, 이미지 3/3
    • Remove the top cover of the device.
    • Remove the five 1.7 mm Phillips #0 screws on the top of the device.
  10. iHome iAVS16 Wi-Fi Antenna Replacement: 10 단계, 이미지 1/3 iHome iAVS16 Wi-Fi Antenna Replacement: 10 단계, 이미지 2/3 iHome iAVS16 Wi-Fi Antenna Replacement: 10 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Remove the Wi-Fi antenna with tweezers.
    • You may wish to completely remove the motherboard for easier access to the Wi-Fi chip and antenna. Please refer to motherboard guide for instructions.
결론
Marco Sousa
회원 가입일: 10/25/19
293 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team S1-G7, O'Connell Fall 2019 UMass Dartmouth, Team S1-G7, O'Connell Fall 2019 회원
UMASSD-O'CONNELL-F19S1G7
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 5
30일 전: 16
전체 시간: 201
