소개
Are you interested in improving the Wi-Fi reception on your iHome iAVS16? This guide will show you how to disassemble the iHome iAVS16 to access the Wi-Fi antenna for replacement.
The iHome iAVS16 is a clock and speaker system with Amazon Alexa capabilities. The device uses a Link Play A31 Wi-Fi module for playing audio content via a wireless Internet connection. Replacing the attached antenna could help to improve the Wi-Fi reception.
You may wish to remove the motherboard for easier access to the Wi-Fi chip. If so, the motherboard guide provides instructions for that process.
Before beginning, make sure to power off the device completely and disconnect from any external power source.
필요한 것
Remove the four 1.7 mm Phillips #0 screws located on the bottom of the device.
Lift up the bottom of the device.
Insert an iFixit opening tool into the lining on the front casing and pry it apart. Do this for both sides.
Further remove the front casing off from the device manually with your hands.
Using an iFixit opening tool, push the tab under the top of the device to create a gap.
Insert the iFixit opening tool in the gap, and slide it across to remove the top casing.
