소개
If your device is producing bad sound quality, you can use this guide to replace the antenna. This guide requires you to open up the iHome to reach the antenna. The antenna may need to be replaced if it gets cut or ripped.
This replacement is best done on a flat surface with plenty of room to work. Opening up the iHome involves the removal of many different screws. It is important to keep track of these screws! You can do this by placing the screws on a magnetic mat in the order of removal. This allows for easy reassembly.
Additionally, the replacement of the antenna involves soldering.
필요한 것
Pull the tab towards you and lift up to remove the battery cover.
Remove the two AA batteries.
Unscrew the four 8mm Phillips #2 screws.
Unscrew the six 25mm Phillips #2 screws.
Reinstall the backup battery cover so it is out of the way.
Set the motherboard assembly upside down to expose the spot of glue holding the antenna to the motherboard.
Pry up the glue with a metal spuger.
