주요 콘텐츠로 건너뛰기
iHome iM71SC Battery Replacement
필요한 것
  1. iHome iM71SC Battery Replacement, iHome iM71SC Disassembly: 1 단계, 이미지 1/1
    • Push down and turn the top of the speaker clockwise. This will release the clips and expand the speaker.
  2. iHome iM71SC Battery Replacement: 2 단계, 이미지 1/1
    • Use a #000 Phillips screwdriver to remove the four 1 mm screws from the bottom half of the speaker.
  3. iHome iM71SC Battery Replacement: 3 단계, 이미지 1/1
    • Flip the speaker over and use a #000 Phillips screwdriver to remove three 1mm screws . Unscrew these to unfasten the top.
  4. iHome iM71SC Battery Replacement: 4 단계, 이미지 1/1
    • Remove the now unfastened coverings to expose the internals of the speaker.
  5. iHome iM71SC Battery Replacement, Battery: 5 단계, 이미지 1/3 iHome iM71SC Battery Replacement, Battery: 5 단계, 이미지 2/3 iHome iM71SC Battery Replacement, Battery: 5 단계, 이미지 3/3
    • Locate the battery underneath the circuit board.
  6. iHome iM71SC Battery Replacement: 6 단계, 이미지 1/2 iHome iM71SC Battery Replacement: 6 단계, 이미지 2/2
    • Unsolder the batterie's wires from the circuit board to remove the old battery.
    • Check out this awesome guide for soldering & desoldering instructions.
결론
To reassemble your device, follow Steps 1-4 in reverse order.
Sarah Brown
회원 가입일: 03/21/17
301 평판
안내서 3개 작성하였습니다
UMass Dartmouth, Team S7-G5, Julie Spring 2017 UMass Dartmouth, Team S7-G5, Julie Spring 2017 회원
UMASSD-JULIE-S17S7G5
5 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 9
전체 시간: 262
