소개
If you are having trouble charging you iPod/iPhone or the audio is not working, you may need to replace the USB and AUX port. This guide demonstrates how to perform these replacements.
필요한 것
Remove the rubber from the bottom of the speaker, use a medium blue plastic spudger to gently work its way under the rubber and slowly peel off for each of the three feet. The order does not matter.
Pry off the mesh frame from the back side of the speaker with a plastic spudger until you hear a click noise when the clip is removed.
Remove the two 11 mm Philips #1 screws holding down the motherboard.
Lift the motherboard from the plastic frame.
