소개
Remove the fan cover to replace your upper fans or hard drive.
필요한 것
Lay the iMac display-side down on a flat surface.
Loosen the three Phillips screws securing the rear panel to the iMac.
Remove the two Phillips screws securing the fan cover to the midplane.
Lift the fan cover up off midplane.
거의 끝나갑니다!
결론
다른 5명이 해당 안내서를 완성하였습니다.
