주요 콘텐츠로 건너뛰기
iMac G5 17" Model A1058 RAM Replacement
필요한 것
  1. iMac G5 17" Model A1058 RAM Replacement, Rear Panel: 1 단계, 이미지 1개 중 1개
    • Lay the iMac display-side down on a flat surface.
    • Loosen the three Phillips screws securing the rear panel to the iMac.
    • These screws are captive in the iMac. The center screw will stop turning after about 3.5 turns and the outer screws will stop turning after about 5.5 turns. Do not try to remove these screws from your iMac.
  2. iMac G5 17" Model A1058 RAM Replacement: 2 단계, 이미지 3개 중 1개 iMac G5 17" Model A1058 RAM Replacement: 2 단계, 이미지 3개 중 2개 iMac G5 17" Model A1058 RAM Replacement: 2 단계, 이미지 3개 중 3개
    • Lift the rear panel slightly from the bottom edge of the iMac.
    • Pull the rear panel toward yourself and remove it from the iMac.
  3. iMac G5 17" Model A1058 RAM Replacement, RAM: 3 단계, 이미지 3개 중 1개 iMac G5 17" Model A1058 RAM Replacement, RAM: 3 단계, 이미지 3개 중 2개 iMac G5 17" Model A1058 RAM Replacement, RAM: 3 단계, 이미지 3개 중 3개
    • Rotate each of the two RAM retaining arms away from the RAM chip.
    • Pull the RAM chip straight away from its socket.
    • Repeat this process for the other RAM chip.
    • Be sure the RAM arms are fully rotated away from the RAM socket before reinstalling any RAM chips.
결론
다른 39명이 해당 안내서를 완성하였습니다.
작성자
8다른 기여자 명과 함께
Walter Galan
701,352 평판
안내서 1,203개를 작성함
댓글 4개
Way too easy. Doubled my RAM in 5 minutes. Computer runs like new again.
Darren Fox - 답글
Can i get 6 or 8 gigs ram?
frederikchalmer - 답글
Do both the ram slots have to have ram in them
Gary Wayne - 답글
When I cut it on the Apple pops up then a colored screen comes up with horizontal lines
Gary Wayne - 답글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 9
지난 30일: 49
전체 시간: 30,615
