이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Lay the iMac display-side down on a flat surface.
Loosen the three Phillips screws securing the rear panel to the iMac.
Lift the rear panel slightly from the bottom edge of the iMac.
Pull the rear panel toward yourself and remove it from the iMac.
Rotate each of the two RAM retaining arms away from the RAM chip.
Pull the RAM chip straight away from its socket.
다른 39명이 해당 안내서를 완성하였습니다.
댓글 4개
Way too easy. Doubled my RAM in 5 minutes. Computer runs like new again.
Darren Fox - 답글
Can i get 6 or 8 gigs ram?
Do both the ram slots have to have ram in them
Gary Wayne - 답글
When I cut it on the Apple pops up then a colored screen comes up with horizontal lines
Gary Wayne - 답글
