소개
Regain wireless connectivity by replacing your broken AirPort/Bluetooth board.
필요한 것
이 단계에 사용된 도구:Plastic Cards$2.99
Insert a plastic card up into the corner of the air vent slot at the top of the rear case.
Push the card toward the top of the iMac to release the front bezel latch.
Pull the front bezel away from the rear case.
Repeat this process for the other side of the front bezel.
Peel back the aluminum EMI shield up off the lower three edges of the rear case.
다른 2명이 해당 안내서를 완성하였습니다.
