주요 콘텐츠로 건너뛰기
iMac G5 17" Model A1144 Display Replacement
필요한 것
  1. iMac G5 17" Model A1144 Display Replacement, Access Door: 1 단계, 이미지 1개 중 1개
    • Before you work on the computer, unplug the computer and press the power button for 20-30 seconds to drain the stored energy in the power supply.
    • Loosen the two Phillips screws securing the access door to your iMac.
    • These screws are captive in the access door.
  2. iMac G5 17" Model A1144 Display Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the access door from your iMac.
  3. iMac G5 17" Model A1144 Display Replacement, Front Bezel: 3 단계, 이미지 1개 중 1개
    • Remove the three T8 Torx screws securing the front bezel to the rear panel.
  4. iMac G5 17" Model A1144 Display Replacement: 4 단계, 이미지 2개 중 1개 iMac G5 17" Model A1144 Display Replacement: 4 단계, 이미지 2개 중 2개
    • Orient the iMac face-up, on its backside.
    • Use your thumbs to press both RAM arms in past the front bezel for enough clearance to lift it off the rear case.
  5. iMac G5 17" Model A1144 Display Replacement: 5 단계, 이미지 1개 중 1개
    • While holding the RAM arms in with your thumbs, lift the lower edge of the front bezel enough to clear the rear case.
  6. iMac G5 17" Model A1144 Display Replacement: 6 단계, 이미지 3개 중 1개 iMac G5 17" Model A1144 Display Replacement: 6 단계, 이미지 3개 중 2개 iMac G5 17" Model A1144 Display Replacement: 6 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    Plastic Cards
    $2.99
    • Re-orient your iMac so it sits upright on the stand.
    • Insert a plastic card up into the corner of the air vent slot at the top of the rear case.
    • Push the card toward the top of the iMac to release the front bezel latch.
    • Pull the front bezel away from the rear case.
    • Repeat this process for the other side of the front bezel.
    • It may be necessary to apply several layers of duct tape to the top of the access card to aid in releasing the latches.
    • If the bezel refuses to release, try pressing the lower edge back onto the rear case and repeat this opening process.
  7. iMac G5 17" Model A1144 Display Replacement: 7 단계, 이미지 1개 중 1개
    • Lay your iMac stand-side down on a table.
    • Lift the front bezel from its lower edge and rotate it away from the rest of your iMac, minding the RAM arms that may get caught.
    • Lay the front bezel above the rest of the iMac.
  8. iMac G5 17" Model A1144 Display Replacement: 8 단계, 이미지 1개 중 1개
    • If necessary, remove the piece of kapton tape wrapped around the microphone and camera cables.
  9. iMac G5 17" Model A1144 Display Replacement: 9 단계, 이미지 2개 중 1개 iMac G5 17" Model A1144 Display Replacement: 9 단계, 이미지 2개 중 2개
    • Disconnect both the camera and microphone cables.
  10. iMac G5 17" Model A1144 Display Replacement, Display: 10 단계, 이미지 1개 중 1개
    • Peel back the aluminum EMI shield up off the lower three edges of the rear case.
    • It is not necessary to peel the EMI shield off the display.
    • We found it helpful to tape the EMI shield up against the display to keep it out of the way.
  11. iMac G5 17" Model A1144 Display Replacement: 11 단계, 이미지 2개 중 1개 iMac G5 17" Model A1144 Display Replacement: 11 단계, 이미지 2개 중 2개
    • Remove the two 5 mm T6 Torx screws securing the display data cable to the logic board.
    • Using its attached black tab, pull the display data cable connector up off the logic board.
  12. iMac G5 17" Model A1144 Display Replacement: 12 단계, 이미지 1개 중 1개
    • Pull the inverter cable connector up off its socket on the logic board.
  13. iMac G5 17" Model A1144 Display Replacement: 13 단계, 이미지 1개 중 1개
    • Peel back the aluminum EMI tape from the two vertical edges of the display.
    • During reassembly, it is helpful to use several small strips of tape to hold the EMI shielding along the left and right edges of the display footprint out of the way before lowering the display into the rear case of your iMac.
  14. iMac G5 17" Model A1144 Display Replacement: 14 단계, 이미지 2개 중 1개 iMac G5 17" Model A1144 Display Replacement: 14 단계, 이미지 2개 중 2개
    • Remove the four recessed coarse-thread 7.5 mm T10 Torx screws securing the display to the rear case.
    • These screws are recessed, so a thin screwdriver such as this is essential for removal. Bit drivers tend to be too short for this application.
  15. iMac G5 17" Model A1144 Display Replacement: 15 단계, 이미지 1개 중 1개
    • Lift the display from its lower edge and pull it toward yourself to peel it off the EMI shield attached to its top edge.
    • Be mindful of any cables that may get caught during removal.
결론
다른 21명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Walter Galan
706,355 평판
안내서 1,203개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 22
전체 시간: 23,118
