주요 콘텐츠로 건너뛰기
iMac G5 20" Model A1076 Optical Drive Replacement
단지 전제 조건
이 안내서는 다른 가이드의 선행 작업으로 사용하기 위한 것입니다. 그 자체로는 불완전합니다.
필요한 것
  1. iMac G5 20" Model A1076 Optical Drive Replacement, Optical Drive: 1 단계, 이미지 1/1
    • Remove the four 7 mm Phillips screws securing the optical drive to the midplane.
  2. iMac G5 20" Model A1076 Optical Drive Replacement: 2 단계, 이미지 1/2 iMac G5 20" Model A1076 Optical Drive Replacement: 2 단계, 이미지 2/2
    • Pull the optical drive up by its white pull tab to disconnect it from the logic board.
    • Lift the free end of the optical drive just enough to clear the fan cover. Lifting the free end of the optical drive too far may break the plastic positioning pins off the front bezel.
    • Lift the free end of the optical drive slightly, then pull it away from the edge of the rear case to clear the two plastic positioning pins.
    • Lift the optical drive out of your iMac.
    • When reinstalling your optical drive it may be necessary to set the bezel attached to the open end of the drive on the plastic positioning pins molded into the front bezel of the iMac and pull the connector side of the drive toward the edge of the rear case, bending it outward slightly, to properly seat the connector.
결론
Walter Galan
694,692 평판
안내서 1,203개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 661
