주요 콘텐츠로 건너뛰기
iMac G5 20" Model A1076 RAM Replacement
필요한 것
  1. iMac G5 20" Model A1076 RAM Replacement, Rear Panel: 1 단계, 이미지 1/1
    • Lay the iMac display-side down on a flat surface (putting a cloth under the screen to protect it from bumps).
    • Loosen the three Phillips screws securing the rear panel to the iMac.
    • These screws are captive in the iMac. The center screw will stop turning after about 3.5 turns and the outer screws will stop turning after about 5.5 turns. Do not try to remove these screws from your iMac.
  2. iMac G5 20" Model A1076 RAM Replacement: 2 단계, 이미지 1/2 iMac G5 20" Model A1076 RAM Replacement: 2 단계, 이미지 2/2
    • Lift the rear panel slightly near the bottom of the iMac.
    • Pull the rear panel toward yourself and remove it from the iMac.
  3. iMac G5 20" Model A1076 RAM Replacement, RAM: 3 단계, 이미지 1/2 iMac G5 20" Model A1076 RAM Replacement, RAM: 3 단계, 이미지 2/2
    • Rotate each of the two RAM retaining arms away from the RAM chip.
    • The chip will partially pop out at the same time as the arms are pulled out to either side.
    • Pull the RAM chip straight away from its socket.
    • Repeat this process for the other RAM chip.
    • Be sure the RAM arms are rotated fully outward before installing new RAM chips.
결론
다른 31명이 해당 안내서를 완성하였습니다.
Walter Galan
696,107 평판
안내서 1,203개 작성하였습니다
댓글 2개
como se llama la cajita blanca que esta debajo de las memorias y que funcion tiene?
max sanchez - 답글
Easy as pie, instructions were right to the point, thank you.
Hemi Andersen - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 17
전체 시간: 23,314
