소개
Instantly increase the speed of your iMac by upgrading the RAM.
필요한 것
Lay the iMac display-side down on a flat surface (putting a cloth under the screen to protect it from bumps).
Loosen the three Phillips screws securing the rear panel to the iMac.
다른 31명이 해당 안내서를 완성하였습니다.
댓글 2개
como se llama la cajita blanca que esta debajo de las memorias y que funcion tiene?
Easy as pie, instructions were right to the point, thank you.
Some models (with light sensor) have only the two outboard screws.
Robert Huber - 답글
