소개
Regain wireless connectivity and replace your inoperative AirPort Extreme card.
Loosen the two captive Phillips screws securing the access door to the iMac.
Remove the access door from the iMac.
Flip your iMac over and lay it stand-side down on a flat surface.
To lift the front bezel off the iMac, simultaneously:
Use your thumbs to press in the RAM arms and hold the iMac down.
Use your index fingers to pull the small bridge of material on the front bezel toward yourself.
Pull the Front bezel up with your index fingers.
Once the small bridge of material has cleared the RAM arms, lift the front bezel by its lower edge just enough to clear the bottom edge of the rear case.
Insert a plastic card up into the corner of the air vent slot near the top of the rear case.
Push the card toward the top of the iMac to release the front bezel latch.
Pull the front bezel away from the rear case.
Repeat this process for the other side of the front bezel.
If the bezel refuses to release, try pressing the lower edge back onto the rear case and repeat this opening process.
다른 4명이 해당 안내서를 완성하였습니다.
댓글 한 개
My intel c2d 17" sold in europe had four T8 screws to loosen front. Not the three T6 and one T8.
