주요 콘텐츠로 건너뛰기
iMac Intel 20" EMC 2133 and 2210 Optical Drive Replacement
단지 전제 조건
이 가이드는 전제 조건 전용 가이드입니다! 이 가이드는 다른 절차의 일부이며 단독으로 사용할 수 없습니다.
필요한 것
  1. iMac Intel 20" EMC 2133 and 2210 Optical Drive Replacement, Optical Drive: 1 단계, 이미지 1개 중 1개
    • If necessary, remove the pieces of tape securing the hard drive/optical drive thermal sensor cables to your iMac.
  2. iMac Intel 20" EMC 2133 and 2210 Optical Drive Replacement: 2 단계, 이미지 1개 중 1개
    • Disconnect the optical drive thermal sensor connector from the logic board by pulling its connector toward the top of your iMac.
    • When removing this connector, it is helpful to use your thumbnails to push the ears on either side of the connector toward the top of your iMac.
  3. iMac Intel 20" EMC 2133 and 2210 Optical Drive Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the two fine-thread 7 mm T10 Torx screws securing the optical drive to the rear case.
  4. iMac Intel 20" EMC 2133 and 2210 Optical Drive Replacement: 4 단계, 이미지 1개 중 1개
    • Lift the free end of the optical drive slightly out of the rear case.
    • Remove the two 3.5 mm T6 Torx screws securing the optical drive connector to the optical drive.
  5. iMac Intel 20" EMC 2133 and 2210 Optical Drive Replacement: 5 단계, 이미지 2개 중 1개 iMac Intel 20" EMC 2133 and 2210 Optical Drive Replacement: 5 단계, 이미지 2개 중 2개
    • Insert the flat end of a spudger between the optical drive connector and the body of the optical drive.
    • Twist the spudger to separate the connector from the optical drive.
    • It may be necessary to work from alternating sides of the connector until it is disconnected.
  6. iMac Intel 20" EMC 2133 and 2210 Optical Drive Replacement: 6 단계, 이미지 1개 중 1개
    • Lift the optical drive out of the rear case and pull it away from the side of the rear case to release the strip of EMI tape attached to its surface.
    • The optical drive thermal sensor is still attached to the underside of the optical drive.
결론
작성자
5다른 기여자 명과 함께
Walter Galan
706,370 평판
안내서 1,203개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 8
전체 시간: 1,027
