이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
Make sure to keep an accurate temperature reading by replacing the ambient temperature sensor cable.
필요한 것
Lay your iMac front side down on a table with the lower edge facing yourself.
Loosen the single Phillips screw in the center of the access door.
Remove the access door from your iMac.
이 단계에 사용된 도구:Heavy-Duty Suction Cups (Pair)$14.95
Stick two suction cups to opposing corners of the glass panel.
Remove the following 12 screws securing the front bezel to the rear case:
Eight 13 mm T8 Torx.
Four 25 mm T8 Torx.
Gently lift the front bezel from its top edge off the rear case.
Once the top edge of the front bezel has cleared the rear case, rotate the front bezel toward the stand and lift it off the rear case.
Rotate the front bezel away from the rest of the device and lay it above the top edge of the iMac.
Pull the LCD temperature sensor connector straight up off its socket on the logic board.
(located at the top of the logic board on the 24")
Disconnect the left speaker cable connector from the audio board by pulling it straight away from its socket.
Disconnect the CPU fan connector from the logic board by pulling it straight up from its socket.
Use the flat end of a spudger to open the cable clip attached to the CPU fan.
De-route the ambient temperature sensor cable from the channel in the CPU fan.
다른 한 분이 해당 안내서를 완성하였습니다.
