소개
Replace a broken AirPort card to regain Wi-Fi connectivity.
필요한 것
이 단계에 사용된 도구:Heavy-Duty Suction Cups (Pair)$14.95
Stick a suction cup near each of the two top corners of the glass panel.
If your suction cups refuse to stick, try cleaning both the glass panel and the suction cup with a mild solvent.
Use the flat end of a spudger to pry all three AirPort antenna cable connectors up from their sockets on the AirPort card.
다른 11명이 해당 안내서를 완성하였습니다.
댓글 한 개
Inversion de CH / CH inversion :
J'ai constaté deux fois le même problème en changeant le HDD.
J'ai connecté normalement et ça fonctionne.
I have seen the same problem twice by changing the HDD.
I connected normally and it works.
Avant / Before : 0 = CH 2/1 = CH 1/2 = CHO
Après / After : 0 = CH 0/1 = CH 1/2 = CH 2
